99 - Serpentine belt squeaking
Old Feb 8, 2005 | 03:18 PM
H2Oskier313's Avatar
H2Oskier313
Hello,
This is my first post on this forum and I've only owned the Expedition for about a month and a half. This forum seems to be a great resource.
My question: I've noticed everytime I start the truck cold, there is a speaking noise that comes from under the engine compartment (what I'm assuming is the serpentine belt). I'm wondering how easy a repair is this to do it yourself? Any special tools, or is this easier/faster to have a mechanic put one on (not a dealership)?
Thanks for any help you can provide.
Old Feb 8, 2005 | 04:00 PM
the4by4freek's Avatar
the4by4freek
Originally Posted by H2Oskier313
Hello,
Sounds to me like you got a bad tensioner pulley. It could be a bad belt but I doubt it. How many miles are on it? If it's over 45,000 I would say change the belt first. Pretty easy job, All you need is a metric wrench and some strength. Just releaase the tensioner and slip the belt off the alternator pulley. Then put the neww belt on according to the pic on the underside of the hood. If it's a tensioner pulley it will come as a complets assembly and it's only 3 bolts that hold it in place. The easiest way to check this is when the belt is off spin the tensioner pulley and listen for bearing noise, also spin the idler pulley and listen for bearing noise. If it's a pulley problem you will definately hear it! If all is quiet then replace the belt and check to see if squeel is gone. I hope this helps!
Old Feb 10, 2005 | 04:05 PM
Rainman15's Avatar
Rainman15
Had the exact same issue with my 98 about 3 months ago. Bought a new good year gator back belt from Autozone for about $40 bucks including tax. Entire process of changing it took less than 10 minutes. Problem solved.
MavSprint
Mar 12, 2013 10:08 AM
jsutton
Nov 27, 2012 11:31 PM
bafm
Oct 19, 2011 05:43 AM
Thudpucker
1997 - 2003 F150
May 27, 2010 12:46 PM
dallen
Feb 3, 2008 06:27 PM
