18 horsepower seems "within reason" for an aftermarket intake system, its more than likely elevated but they always are, for our trucks or even rice burners.
However, when i first saw 114 ft lbs of torque, i figured it was a misprint.....then i saw it again.......there is no way in heck its 114, or did u mean 14 and misprint it twice?
But if it is 114 ft lbs, those guys runnin the dyno are smokin the crack pipe, next thing someone will try selling me spark plugs for my truck so the fuel burns better and get an extra 300 hp
I buy the 18 hp... but there is a linear equation between hp and torque and NO WAY a 18 hp increase equates to a 114 lbft increase !!!!!!
The power is made at a very low RPM- it helps to pick up the torque earlier; it is most likely making torque at a point where it was making next to none previously. I beleive the numbers, you just have to keep in mind exactly how they are derived.
According to most I have heard from, there is actually a serious seat of the pants improvement with the new Stage 2 setup- something not reportedly obtained with most other intakes for the 6.0
114 is claimed at 850 RPM, maybe most of the gain is gone by 1200?
(HP*5252)/torqu = RPM and (18*5252)/114 = 830 RPM, so the 850 is close to right math wise.
But if their peak gain is 18 hp, then the 114 lb-ft of more torque at 830 RPM would have to plummet after that. By 1000 RPM the torque gained would have to be down to 95 lb-ft to not exceed 18 HP. At 2000 RPM it would be down to half that.
Common sense wise though it doesn't quite seem right to me. Not being an intake designer I'd think that you'd expect an intake to provide more improvement on the top end than down low where the volume of air being drawn/pushed through the air cleaner is much less.
area under the dyno curve is where performance is felt. if the torque numbers are down low in the rpm...which makes sense for the numbers they are posting, there should be some feel off line. my question is...i'd like to see this unit in combination with a tuner. anyone have comments on this idea?
There was a link to the pdf on that page with a small dyno graph in it.
Those look reasonable and believable. If that's the case, the gain may be worth it to some people to purchase it...definately seems to have more improvement than many of the other intakes.
Reason: remove img
I would imagine the compound effects would be greater with stronger fuel tuning, as it would give the air something to burn...
It is a nice looking curve. Don't get me wrong, I'd love 114 lb-ft more torque down low.
But my curiosity still remains, if they are flowing that much more air, why the large gain at low RPM and little gain at higher RPMs where the engine needs more air.
Some other limiting factor must start to kick in around the mid 800 RPM range pulling down the torque output, or maybe due to some wierd aerodynamic thingy the filter doesn't flow that much better at high RPMs.
Or possibly their relocation of the MAS has caused the motor to think it's getting a lot more air at low RPMs and fuel up accordingly.
