Any help fixing a P302 code on a 97 EB Expedition? Engine has started to miss, and hesitate lately with Engine light on. Anyone ever run into this? Possible fixes? Thanks.
well if it is missing you may have a bad plugs, wires, cap/rotor. If you still have the original stuff might be time for replacement.
If memory serves correctly P302 is a misfire code.
The misfire detection monitor is designed to monitor engine misfire and identify the specific cylinder in which the misfire has occurred. Misfire is defined as lack of combustion in a cylinder due to absence of spark, poor fuel metering, poor compression, or any other cause.
Possible Causes:
Ignition system
Fuel injectors
Running out of fuel
EVAP canister purge valve
Fuel pressure
Evaporative emission system
Base engine
Diagnostic Aides:
The MIL will blink once per second when a misfire is detected severe enough to cause catalyst damage. If the MIL is on steady state, due to a misfire, this will indicate the threshold for emissions was exceeded and cause the vehicle to fail an inspection and maintenance tailpipe test.
