i have no clue maybe someone else can help you the build sheet is also under you seat in between the springs and the foam you can see it clearly if the seat is removed it is even more deatailed than the one ford sent you it gives times part numbers shift number start time and finish time
Is it a Sno Fighter that came with a plow on it? Do they mean the mounting places on top of the plow frame for the parking lights? If you can post a copy of the build sheet.
In addition to what f150daniel said, my buildsheet was in the same location except on the passenger side also in excellent condition. As far as those option codes I can't help ya much there.
Ford Customer Service Division Ford Motor Company
February 2, 2005
Dear Mr. Brady:
16800 Executive Plaza Drive P.O. Box 6248
Dearborn, Michigan 48126
Thank you for your recent contact with the Customer Relationship Center.
You asked the CRC to provide you with the original specifications and optional equipment for your vehicle at the time of manufacture. Your vehicle identification number F26YEV80376 decodes as follows:
F26YEV80376
F26 = F-250 Pickup 4x4
Y = 360 cm 8-Cylinder 2V
E = Mahwah Assembly Plant
V80376 = Consecutive Unit Number
This vehicle was produced on 01/22/1975 with the following options:
133" Wheelbase
Dark Ginger Metallic Exterior Paint Styleside Pickup
Parchment/Ginger Cab & Trim
GVW is 6,500 Ibs.
Orange Tape Stripe
Ammeter
Oil Pressure Gauges
New Process 435 4-Speed Transmission 4.10 Non-Locking Rear Axle
Power Steering
750x16-8 TT Mud & Snow Tread Tires
Mud & Snow Spare Tire
Left & Right Hand Chrome Western Swing Lock Mirrors
Pickup Box Cover
Bodyside Moldings
AM Radio
Sliding Rear Window
Exhaust System
36" Parking Light Mounting
I can't go to the seat for info. as the cab has been replaced due to fire.
Have a great day
ArmstrongFordTrucks
Reason: Removed code & spacing to shorten Length of post.
I just looked under my passenger seat and found the build sheet, thanks for the tip guys. Unfortunately the upper right corner of the paper is torn and missing. I didn't see it, but I can only get at the truck from the passenger side due to it being storage for winter. Would they have put one above the headliner also as somebody else mentioned or is there just one per truck?
It is extremely detailed, but how do you decode it? Some of it is obvious, but other codes are not. Any suggestions as to how to find out the info on it? Also somebody mentioned the build sheets ford currently mails are not as detailed? As I don't have one to look at how do they differ? Thanks for any help.
From what I understand it could be under the seat, headliner, or even under the flooring if you have the carpet or rubber floor. I dont think it went by year or anything, just were ever the person wanted to put it. If it even had one placed in it.
Build sheets are found in many different places. Or no place. The line workers put them wherever. Quite often they weren't put in the truck at all or several different ones were put in the same truck.
I bought a new '77 F250 and the build sheet was shoved in the frame between the frame rail and fuel tank.
