Wheel Wobble
Old Feb 7, 2005 | 02:14 PM
okwaho1650's Avatar
okwaho1650
Wheel Wobble
when i turn to the left my wheel feels like it is wobaling real bad and i cant find anything wrong help
Old Feb 7, 2005 | 03:04 PM
ford390gashog's Avatar
ford390gashog
what have you checked so far did you pull the rotor and the bearings out yet
Old Feb 7, 2005 | 05:58 PM
okwaho1650's Avatar
okwaho1650
i pulled the cap that holds the barings off and did not see anything and the barings did not feel bad
Old Feb 7, 2005 | 07:20 PM
zwinstead's Avatar
zwinstead
slow speeds??? high speeds??? turned all the way to the left??? tie rods loose???
Old Feb 8, 2005 | 03:37 PM
okwaho1650's Avatar
okwaho1650
eather speeds and only at about a 30% turn in the wheels
Old Feb 9, 2005 | 01:04 PM
martin_b's Avatar
martin_b
Jack up the front end and check for play at the wheel. Pretty much any play is bad. Could be tie rod ends, wheel bearings or ball joints.
Old Feb 9, 2005 | 01:23 PM
acdc_rocks6's Avatar
acdc_rocks6
when u break too the rotor can hea up n warp a little cause'n this. happend to me
Old Feb 9, 2005 | 01:33 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
i second that, put it on jack stands and try to "wiggle" every steering component, there shouldnt be any play anywhere, except the steering links which may turn slightly but shouldnt have much play in them at all, other than that check your tires for bubbles on the sidewalls inside and out, you might have a busted belt in one..........
Old Feb 9, 2005 | 09:33 PM
FordTruckTechNut's Avatar
FordTruckTechNut
Is it a 4WD ?could be a stuck lock out? only turning one way, not wobbling while driving not thinking bearings. answered my own question if the truck you are describing is in your gallery, what about kingpins?
Old Feb 10, 2005 | 12:44 PM
samickguy15's Avatar
samickguy15
Wobble
If everything mechanical checks out, spin the tire and look for radial runout towards the outside edges of the tread. Either that or go to your local tire place and have them "Road-force" balance the wheel.
Old Feb 12, 2005 | 12:48 PM
okwaho1650's Avatar
okwaho1650
it was the drag link thank yall for the help
Bigbruce
Jun 23, 2013 08:35 AM
pittmick
Oct 12, 2010 08:57 AM
fuzzy1626
1983 - 2012 Ranger & B-Series
Mar 16, 2008 11:35 AM
MER
Mar 8, 2008 09:28 PM
Newsheriff706
Oklahoma Chapter
Jun 16, 2007 07:27 AM
