flashing OD light
Old Feb 7, 2005 | 07:41 AM
lewjayjr's Avatar
lewjayjr
flashing OD light
I have a 99 F150 with the 4.2 eng and auto trans. This truck has the factory 6000lb towing pkg,and I use it occasionally to tow my 20 ft boat (about 4000lb).
Got in the truck this morning to go to work, and the OD light started flashing. I thought maybe it was something to do with being cold but on down the road after it warmed up, it was till flashing. I stopped and checked the fluid (in PARK with eng running). Fluid level was normal and no burned smell. The truck seemed to drive OK but was "clunking" some.
I've checked the manual and it has nothing in it about this.
The truck has 82000 on the clock and the tranny was serviced around 60000.
Anyone have any ideas???
Old Feb 7, 2005 | 08:14 AM
shane1's Avatar
shane1
od
run codes on ecm that will tell mine started doing that and the code was 688?
dont rem, was 6 something anyway its slipping tourqe converter i don spell so well. hope this helps, dave
Old Feb 7, 2005 | 10:08 AM
Casey's Avatar
Casey
A flashing OD light means something is wrong with the transmission. You need to have the code read to find out what's wrong. Anything else is a SWAG.
Old Feb 7, 2005 | 10:54 AM
lewjayjr's Avatar
lewjayjr
Ok, I watched the tach to make sure it wasn't slipping or anything. I'll try to get it looked at ASAP,
Old Feb 7, 2005 | 11:37 AM
shane1's Avatar
shane1
run code scanner on it first thing to do
Old Feb 7, 2005 | 07:18 PM
lewjayjr's Avatar
lewjayjr
Follow up
I went to the Auto Skills Shop here at Ft Benning, and they ran the scanner on it. Of course when I drove over there, it was doing everything right. Well, the code was 2-3 upshift.
Guy at the auto center said if the light comes on again, bring it back and we'll rescan to see if it's the same thing. It was no charge which was nice.
My wife has a lady friend who's son works at a Ford Dealership as an auto trans tech. I'm gonna check with him to see what's going on.
Old Feb 11, 2005 | 11:14 AM
NSTAG8R's Avatar
NSTAG8R
I have a 1999 F-350 with overdive. My od light started flashing also. The problem with mine was the VSS (Vehicle Speed Sensor). Mine is located on the top of the rear axle. Maybe that will help you a little.
Old Feb 14, 2005 | 02:48 PM
lewjayjr's Avatar
lewjayjr
Well, I went to Aamco today, and found that the transmission is going bad, or at least that's what they told me. They want $1200 to rebuild the tranny.
Said that the fluid was brownish and going bad, but I still want a second opinion before I let them do anything.
Old Feb 15, 2005 | 05:51 PM
deanj's Avatar
deanj
I just went through the same thing on my 94 F350 Turbo diesel. Not sure if you have the same trans. My symptons were O/D lite flashing, long time between shifts, shifts and will give you whip lash. Went through a lot of diagnostics (look up pre power stroke, O/D lite flashes) finally replaced the rear end speed sensor (procedure in the same forum) works like a charm.
Old Feb 23, 2005 | 01:37 PM
lewjayjr's Avatar
lewjayjr
Well, the truck is at the transmission doctor getting a rebuild. Talked to some friends and got 2 opinions on this one guy so I took it to him. Transmission is bad, and has to be rebuilt. Gonna run around $1300.
Slash19
May 11, 2024 09:06 PM
JEFFRO67
6.7L Power Stroke Diesel
Oct 31, 2016 11:55 AM
DirtMcGurt88
Oct 12, 2016 09:26 AM
ImAGirl
Aug 3, 2015 03:13 AM
lamarafronhe
Jul 7, 2004 09:10 PM
