diff swap/or ????
Old Feb 6, 2005 | 01:10 PM
biggfrank1963's Avatar
biggfrank1963
Exclamation diff swap/or ????
i have an 1967 ford f-250 with a 1 ton rear, looking to change it to a limited slip/ or change the gears in existing housing. but i still want to keep the axle shafts, since i still want to keep the 8 lug pattern
Old Feb 6, 2005 | 08:11 PM
Ford_Six's Avatar
Ford_Six
There are tons of options for the D60 full float, but it is a really heavy axle. Go to Randy's Ring and Pinion or Drivetrain Direct to see your options. The cut-off point for this axle is 4.10, so 4.10 and higher (numerically lower) uses one carrier, while anything lower than 4.10 (numerically higher) uses a different carrier.
Old Feb 10, 2005 | 10:29 PM
biggfrank1963
Thumbs up
ford_six, thank you for the info, i will check it out just as soon as i can
