gritty oil residue
Old Feb 5, 2005 | 03:24 PM
thinksnow's Avatar
thinksnow
gritty oil residue
I was installing my CCV bypass kit today and notice a gritty oily residue in the second tube just before the turbo. THe first tube, off the air filter was spotless. I realize the oil is from the crank case vapors but why the grittyness? Do I have a leak? Is this a sign that Im dusting my motor? My next planned purchase is the upgraded factory intake, maybe I should get it quicker then planned.
Old Feb 5, 2005 | 04:55 PM
Saguaro_7.3's Avatar
Saguaro_7.3
I take it you have a stock air box. What year is the truck? I have a '97 and you have to be real carefull when putting the box back together. Take the rubber hose that goes to the turbo OFF when putting the lid back on, then put the hose on after everthing is tightend down. If you leave the hose on it will put pressure on the lid in one direction causing the lid to not sit correctly. I think I am going to try Kwik's NAPA # 6637 idea and leave the air scoop from the front grill in place. I figure it will cost all of $40.
Old Feb 5, 2005 | 05:03 PM
thinksnow's Avatar
thinksnow
I have a '02. I thought they sealed a little better. Im difinetly going with the upgraded are box. THe truck only has 38K on it, I dont want to take a chance of dusting the motor
Old Feb 5, 2005 | 05:08 PM
Saguaro_7.3
Yea, the '02 has a different air box. I think they are supposed to seal better, but I don't have any experience with them. Good luck.
motogeek
May 25, 2014 09:06 PM
captfatboyf250
Dec 11, 2013 06:52 PM
Kdr358
22
Aug 5, 2013 12:04 AM
PSDx3
6.4L Power Stroke Diesel
Jul 21, 2013 06:21 PM
johnnyk
Feb 8, 2005 09:32 AM
