Help!!
Old Feb 4, 2005 | 11:05 PM
jakemb's Avatar
jakemb
Help!!
Bought 94.5 F-250 with 7.3 powerstroke.Seems to run ruff at idle and after 200 mi. ride found oil level up about half inch.Seems to be getting fuel in the oil.Where to start,injectors? Would this much fuel be caused by injector o-rings?
thanks for any help.
Old Feb 5, 2005 | 06:41 AM
Quadzilla's Avatar
Quadzilla
From what you describe, injector O-rings sounds like the cause. O-rings can fail in many ways, yours sound like the ring between the fuel and high pressure oil system is leaking. That's something you can repair yourself, and I'd make it a high priority item.
Old Feb 5, 2005 | 07:40 AM
Kwikkordead's Avatar
Kwikkordead
What Quadzilla said, and do it ASAP.
Old Feb 5, 2005 | 02:31 PM
ltfox's Avatar
ltfox
Question..........its seems to me if the leak was between the high pressure oil side and the fuel side that your would have oil in the fuel. Not fuel in the oil. Right, or am I crazy.
j1msevier
Mar 6, 2013 06:14 PM
dwcranger
Dec 30, 2011 07:27 PM
Justin460
Jul 1, 2007 05:32 PM
StevensPoint
Sep 30, 2004 02:16 PM
needmorepower
Aug 13, 2002 10:30 AM
