Offroad & 4x4
Old Feb 4, 2005 | 05:25 PM
84 Diesel's Avatar
84 Diesel
Question ?
couple questions. first of all i have a 1984 F-250 4x4 diesel Extended cab. im thinking of lifting it anywhere from 2-4 inches. is there anything (gas lines, brake lines, driveshafts, etc.) that i need to extend. also does anyone know where to find a cheap lift? and last- im pretty sure i have a solid front axle but is it solid or ttb?
Old Feb 4, 2005 | 05:58 PM
2classics's Avatar
2classics
should be ttb. One tons had solids in the 80s
Old Feb 5, 2005 | 01:41 AM
threefiftyone's Avatar
threefiftyone
TTB, unless someone converted it. '86 is when 350's started using solid fronts. You shouldn't have to extend anything. At most brake lines, and most brands use brake line extensions. Rough Country makes inexpensive lifts.
Old Feb 5, 2005 | 07:40 AM
bremen242's Avatar
bremen242
You'll need the extended brake lines. the original 80-86 lines are really short. Try the brake lines form a 90 F250, you'll have to get 2 from the passenger side (trust me, driver's side has some weird hookup on them), I'm pretty sure they are about 4" longer.
You'll have sway bay drops too if you have sway bars.
Old Feb 6, 2005 | 08:19 PM
fishmanndotcom's Avatar
fishmanndotcom
yes there sure is and it's extremely important!
SEARCH!!!
i promise you we have covered this on many occasssions! also it is common sense, get under your truck and see what mgiht or might not need modification!
-cutts-
David Fehir
Feb 8, 2016 09:19 PM
al0311
Feb 8, 2016 06:56 PM
86-f250
Apr 17, 2009 10:40 AM
bob_351
Jun 1, 2008 10:12 PM
ech0sh4y
Offroad & 4x4
Mar 1, 2008 07:04 PM
