still wizzing
Old Feb 4, 2005 | 12:04 PM
bryan_h6121's Avatar
bryan_h6121
Question still wizzing
I posted a concern about the throwout bearing in my '87 f250 w/302 4-speed manual. It made an annoying wizzing noise while driving, or sitting in neutral w/the clutch out. I had the clutch replaced and it it still wizzing. Do these manual transmissions have a history of noisy bearings? And what tranny fluid do most of you use,gear oil or ATF. My '90 ranger w/5-speed, performed best w/ATF.
Old Feb 4, 2005 | 04:02 PM
92supercab's Avatar
92supercab
Don't quote me but I beleive the four speeds use gear oil and the five speeds use ATF. You might want to take it back to where ever you had the Clutch done and ask them if they no why it is doing it. If you put the clutch in yourself, did you put grease on the throw-out bearing, replace the throw out bearing or check the fork that moves the throwout bearing for wear. Also are you sure the tranny level is toped off?
Old Feb 4, 2005 | 05:05 PM
tex94F250's Avatar
tex94F250
I hate to ask, but did they or you replace the throw out bearing when the clutch was done? As 92 says check the fork and the shaft the bearing runs on.
Old Feb 4, 2005 | 09:28 PM
bryan_h6121
throwout bearing was replaced,yes.just got it back a few days ago. will check the fluids...thanks.
oldmongo
Electrical Systems/Wiring
Oct 24, 2024 01:58 PM
Power of 8
May 10, 2013 06:13 AM
my79f
Apr 28, 2009 11:49 PM
70T351W
Aug 30, 2008 02:05 PM
highboy_73
1983 - 2012 Ranger & B-Series
May 8, 2003 05:24 AM
