Need info on E7TE heads
Old Feb 3, 2005 | 02:40 PM
serving_time's Avatar
serving_time
so far everything I have heard sounds like these heads would be a good upgrade to my stock 5.0 heads, at a reasonable cost.
what i have so far, is that these heads can be found on 87 and later 5.0 and 5.8 engines except on crown vic/marquis.
they are supposed to flow better through the port and chamber than my stock heads and would give me great improvements with mild porting.
what I want now, is any tech. info on the heads. Valve sizes, chamber sizes, comp ratio, and specific vehicles that they are on if the above info is incorrect.
I will be going to a wrecking yard to try and find these, and the specific vehicle that they are on would help a lot.
Old Feb 3, 2005 | 02:51 PM
2Wise4aGM's Avatar
2Wise4aGM
Depending on what year truck you have--You probably already have E7TE heads. They were used on truck 302's from 87 on I believe.
Old Feb 3, 2005 | 11:17 PM
cougar_1987's Avatar
cougar_1987
They were also used on 1986 or 87 up 5.0 HO's in Mustangs, and Lincoln LSC's.
Old Feb 4, 2005 | 12:39 AM
serving_time
Now I am finding out that these are a common head.
Does anyone have any experience with doing work to these`heads? Are they worth spending any money on?
What did GT40 cast heads come on? Do they need work done to them? And how do they compare to the E7TE's?
I want to try and save some money over buying aftermarket heads, but so far all I know for sure is that some heads are better than some other heads, but not weather they need work or not, and not how anything compares to anything else.
I have never run any heads other than what was on the engine. Now I want to spend a little money and get something better, but the only info I have got so far is that I can get better heads and there are different types of better heads.
If anyone can give me some info about how a type of head will perform, and the work and money involved that would be great.
Old Feb 6, 2005 | 02:28 AM
matt17's Avatar
matt17
e7's
86 H.O's did not have e7's,they had e6's.
Old Feb 6, 2005 | 03:38 PM
cougar_1987
Thats why I said 86 or 87. I couldn't remember if it was 86 or not because the Mustang recieved multiport fuel injection for 1986 and I thought it might have gotten the E7 heads too.
Redneckfordf2502002
Apr 6, 2016 11:10 AM
theatron52623
Feb 23, 2016 10:42 PM
nothercrash
28
Mar 19, 2014 11:09 AM
81fordf-250
Jan 16, 2007 11:18 AM
tastyklair
Apr 5, 2004 02:03 PM
