Bronco II Ford Bronco II
88 Bii
Old Feb 2, 2005 | 02:47 PM
rlprlp's Avatar
rlprlp
88 Bii
Where is the rear windshield washer resevoir and how do i get to the pump. I believe its behind the tail light, but when i had the tail light out i didnt see it. Tried pouring fluid into in and it doesnt run onto the ground so i assume its still there. Thanks
Old Feb 2, 2005 | 07:16 PM
86 Bronco 2's Avatar
86 Bronco 2
Try looking inside the rear of the Bronco on the driver side and there should be a panel that will come off. Once that is done you should see the resevoir.
Old Feb 2, 2005 | 07:20 PM
rlprlp's Avatar
rlprlp
Cargo compartment or the liftgate and thanks in advance.
Old Feb 4, 2005 | 10:17 AM
GrayRanger4x4's Avatar
GrayRanger4x4
Cargo compartment.
VONxRUBENxLA
Mar 24, 2013 10:43 AM
Psyclopse
Mar 25, 2012 10:22 PM
brcwelding
Nov 13, 2011 08:55 AM
CounterMaker
Jan 21, 2007 10:50 PM
vancouverpower
Jan 27, 2006 10:48 PM
