Sponsored by: Real Truck
tail lights
Old Dec 20, 2012 | 07:13 AM
VONxRUBENxLA's Avatar
VONxRUBENxLA
tail lights
got a problem with my tail lights to be exact its my running light.
i have brake lights turn signals and hazrads but no running lights. could it be the bulb or the harness??
Old Dec 20, 2012 | 07:36 AM
projectSHO89's Avatar
projectSHO89
Do you have front running lamps or are they also out?
If both front and rear are out, it's probably a fuse, relay, switch or similar. If the fronts work but the rears don't, it may very well be a wiring harness or connector problem.
Old Dec 20, 2012 | 09:51 AM
jetjockey99's Avatar
jetjockey99
if the front lights work start with the rear bulbs, they are a dual filament bulb, unusual for both to go out at the same time but it can happen. If it is not the bulbs I would suspect a harness connector issue, ie. corrosion where the rear harness plugs into the harness to the front.
Old Dec 20, 2012 | 11:18 AM
dagren99's Avatar
dagren99
look over the connectors closely - not uncommon for bulbs to not make good contact w/ the connectors. These trucks are getting just old enough that this kind of weird stuff starts happening. The sockets are cheap ~ 20 bucks.
Old Mar 24, 2013 | 10:43 AM
VONxRUBENxLA
so tried swapping out bulbs that want the problem then when i put the old ones back in they decided to start working. and then now they are back to not working again. WTF???
YellowBusBrahh
Electrical Systems/Wiring
Jan 19, 2013 08:45 PM
86'F-150
Jan 14, 2013 10:48 PM
mdbbrown
Dec 28, 2012 01:26 PM
marc13
May 8, 2010 07:29 PM
emgee
Aug 19, 2009 01:40 PM
