Push Button Start 78 F150
Old Feb 2, 2005 | 01:52 PM
KJKozak2's Avatar
KJKozak2
Greetings all.
I did a search on this and got some helpful info, but still have a few questions. I understand how to get the push button itself to work, and I know how complex the key switch is. I plan to replace the whole key switch with toggles and a push button.
As far as I can tell, I only need two toggles - one for the acc. side and one for the "on" side (or whatever it's called).
Can someone tell me if that's correct or did I miss something?
Thanks!
Kevin K.
Old Feb 2, 2005 | 02:10 PM
Dealford's Avatar
Dealford
You'll need at least 2. Starter(optional push button) and ingition/guages etc.
A third to play the radio without running the ignition is optional.
Plan "B"........ Fix it properly & you're good to go !
AL.
Old Feb 2, 2005 | 02:22 PM
KJKozak2's Avatar
KJKozak2
Thanks.
There's nothing to "fix" though. I'm replacing the entire dash and guages with a custom built one and don't want the key switch.
Kevin K.
Old Feb 2, 2005 | 10:35 PM
Franklin2's Avatar
Franklin2
Be careful with the "on" side. If the factory switch has seperate sections for the hot in run wires, then you are going to need a seperate switch or a multi-pole switch for each section. If you take seperate hot in run sections and just twist the wires together and put them on one switch, you may find your starter wants to run all the time, or something crazy like that. If your starter solenoid has only one small terminal, and not two, it can happen.
Old Feb 3, 2005 | 07:45 AM
KJKozak2's Avatar
KJKozak2
Thanks Dave.
I read that in another post, too. I'm pretty sure my solenoid has two terminals, but I'll look for that when I take the switch apart.
K.
QwkFox
Electrical Systems/Wiring
Dec 25, 2013 09:27 PM
rckslash2010
16
Mar 21, 2010 10:02 PM
zpmps2
16
Jan 31, 2008 08:42 PM
beaners1
Feb 13, 2007 08:53 PM
Wagion
Aug 22, 2003 08:45 AM
