Front Shock Question
Old Feb 2, 2005 | 10:23 AM
gomsu's Avatar
gomsu
I have two Ford Rangers, as 1991 2wd STX 3.0L and a 1988 2wd XLT 2.3L. The '91 is a regular cab long box, the '88 an extended cab. My '88 has a junk motor, but brand new shocks that I would like to put on the front of my '91.
Does anyone know what the difference is in the shocks and whether the shocks from the '88 will work on the '91? NAPA tells me they have different part numbers and they won't break the seal on the box to make a comparison. I guess I could take one shock off of each truck and see, rather not, but to me they look to be the same shock. Suggestions or advice is appreciated...aren't these trucks the same chassis?
Old Feb 2, 2005 | 10:35 AM
da'Moose's Avatar
da'Moose
There is a model change difference in the years. I am not sure when there was a change, but the body style is different between the two years. I do believe that there was a up grade in the running gear as well. Yes they are close but not close enough.
Da’Moose
Old Feb 2, 2005 | 10:37 AM
gomsu's Avatar
gomsu
Yeah, the front clip is different, cosmetic, but if structurally they're different too then I guess they won't work as you said. Thanks.
bismic
Jun 26, 2018 08:47 AM
gov2mod
1978 - 1996 Big Bronco
Aug 16, 2016 06:34 PM
mattt181
WTB - Ford Trucks & other vehicles
Nov 14, 2015 12:51 PM
b2trausch
Oct 23, 2007 08:36 AM
TimH
Jul 2, 2005 01:56 PM
