speedometer removal
Old Feb 2, 2005 | 06:14 AM
nayr's Avatar
nayr
speedometer removal
how do you remove the speedo cable from the back of the odometer.
Old Feb 2, 2005 | 06:21 AM
IronWorker3's Avatar
IronWorker3
I took mine out of my 77 a couple of times when I had a wiring problem. It will pull off. Sometimes it's a pain. I got mad and gave it a good yank once and had to replace it yesterday.
Old Feb 2, 2005 | 01:04 PM
nayr's Avatar
nayr
I took those little two bolts out of the back and gave it a pull, i guess i'll just have to yank an little harder.
Old Feb 2, 2005 | 01:29 PM
loudfords's Avatar
loudfords
You don't need to remove any bolts to detach the speedo cable, There is a plastic collar on the end of the speedo cable, you need to push it towards the center of the cable and then pull on the cable. Maybe someone here has a picture from a manual that they can show you?
Old Feb 2, 2005 | 03:09 PM
beartracks's Avatar
beartracks
Yeah, just squeeze and jiggle it loose.
Old Feb 2, 2005 | 04:33 PM
bulrydr_1's Avatar
bulrydr_1
On some trucks the plastic retaining collar does become brittle. If you break yours, most parts stores carry them for pocket change....
Old Feb 2, 2005 | 04:40 PM
79RangerJoel's Avatar
79RangerJoel
Mine was so contrary that I had to get a pair of channel-locks and open them wide, then gently squeeze that white plastic clip to get the cable to come loose. Point the opening of the wrench down, you have to squeeze it along a horizontal line, if that makes sense. At least I did. The manual tells it like, "Just give it a gentle squeeze and POP! it'll come right off." Right. Don't get too frustrated, just keep workin' at it. Gentle squeeze with some wide-mouth pliers ought to do it.
Old Feb 2, 2005 | 08:28 PM
nayr's Avatar
nayr
thank you gentlemen.
Old Feb 2, 2005 | 08:46 PM
Mil1ion's Avatar
Mil1ion
Old Feb 2, 2005 | 08:52 PM
IronWorker3
Talking
Just give it a gentle pull, or if you really get miffed, buy a new speedo cable ahead of time. Like I said it was a bugger to get off then a good heart-felt yank took care of the problem!
Old Feb 2, 2005 | 08:55 PM
IronWorker3
Mil1ion, your post is quite suggestive. Sorry for bustin' your stones.
Rand
1983 - 2012 Ranger & B-Series
Oct 21, 2002 08:34 PM
fatforty
Mar 27, 2001 09:05 PM
bmccl
Aug 28, 2000 07:44 PM
BrentP
Feb 21, 2000 01:39 AM
