I need some advice!!
Old Feb 2, 2005 | 05:53 AM
Peties3's Avatar
Peties3
I would like to get my speedo corrected in my 86 F150. I know it is way off and have FINALLY got the silly thing to run right. Now I am down to getting the speedo correct.
Here is what I have:
86 F150 with a 302.
Trans. type K
Axle type 18
Tires are P235/75/R15
I know on this type of tranny it is just a matter of changing the speedo gear but which one do I need?
Mark
Old Feb 2, 2005 | 07:01 AM
fordborn's Avatar
fordborn
First off is the speedo fast or slow?
Old Feb 2, 2005 | 07:18 AM
Peties3's Avatar
Peties3
It is really slow.
Mark
Old Feb 2, 2005 | 08:49 AM
fordborn's Avatar
fordborn
You would need to put a gear on with less teeth on the cable. Need to know how much slower and might be able to figure out the formula or just get one with say 2 teeth less and try it.
Old Feb 2, 2005 | 10:26 AM
fordnut1985's Avatar
fordnut1985
Hey Mark,
Here is a link to TCI transmision's gear calculator, enter the numbers and it will tell you what gear you need.
http://www.tciauto.com/tech_info/speedo_gears.htm
Duane
Southeast Kansas Coordinator
Old Feb 2, 2005 | 01:08 PM
Peties3's Avatar
Peties3
Duane, Would you have any idea what the ratio this axle is by looking at the code I posted?
Mark
Old Feb 2, 2005 | 01:35 PM
fordborn's Avatar
fordborn
According to the chart it should be a 3.00 check the following thread.
https://www.ford-trucks.com/forums/s...ht=axle+codes+
Old Feb 2, 2005 | 01:40 PM
stlthf1's Avatar
stlthf1
Mark,
If you've changed Tires size this link will help you figure that:
http://www.miata.net/garage/tirecalc.html
Old Feb 2, 2005 | 01:45 PM
Peties3's Avatar
Peties3
Well it looks like I will need to pull the speedo gear out to see how many theeth are on the drive and driven gears.
Bummer!!!!
Mark
Old Feb 2, 2005 | 01:52 PM
Peties3's Avatar
Peties3
According to Jons link, I am 9% off on my speedo. 60 mph = 65.3 actual.
Thanks Jon!!
Duane, without putting too much thought into this, will a driven speedo gear that is 9% smaller give me the correct readings?
Mark
Old Feb 2, 2005 | 02:38 PM
fordborn's Avatar
fordborn
Mark, Might be easier to just paint it White that should be good for at least 5mph.LOL
Old Feb 2, 2005 | 04:01 PM
fordnut1985
I thought code 18 was a 3.08 gear 3800# capacity open diff??
Mark, You should pull the drive gear out of the tranny and see what color it is. Then look at the door sticker and see what tire size originally came on the truck. Then call ford and tell them what the truck originally had for axles and tires then tell them what you have now. If they ask your tires revolution constant is around 9.72.
Just going with a drive gear that is 9% smaller won't work since the ratio for the gear is a combonation of both gears so using a 9% smaller gear will get you about 12% speedo difference.
Duane
Old Feb 2, 2005 | 04:18 PM
fordnut1985
I just did all the math and pulled the drive gear out of my 85 just to check, then called ford and you need a 17 tooth gear to correct the speedo, and they run about 8 bucks.
Duane
Old Feb 2, 2005 | 05:05 PM
Peties3's Avatar
Peties3
WOW!!!impresive Duane!!!
Thanks!!!!!
Mark
Old Feb 2, 2005 | 05:55 PM
fordnut1985
Any time man.
Duane
tjcprop
2004 - 2008 F150
Apr 18, 2014 06:59 AM
Bobby82490
1997 - 2003 F150
Sep 4, 2008 07:30 PM
riverdog
May 20, 2007 04:08 PM
881504x4
Feb 25, 2005 05:25 PM
fiend
1978 - 1996 Big Bronco
Feb 4, 2003 09:16 PM
