C4/D20 Swap in Progress
Old Feb 2, 2005 | 12:07 AM
Lifted94XLT's Avatar
Lifted94XLT
well, I started my tranny/t-case swap last sunday. its a Ford C4 auto 3-speed out of a 70s model Bronco that I rebuilt myself. I also installed a B&M Transpak Shift kit. The transfer case is a D20 out of the same Bronco and it has Twin Sticks. my buddy TJ came by the house with his tow rig and trailer and we trailer the Sploder to his place. while he went out to eat I stayed behind and started workin on her....
here's a quick breakdown of the progress so far....
Sunday::
Removed both front seats, pulled back the carpet to the back seats, unbolted the factory plate covering where the manual shifter would come up if I had a manual tranny. I then unbolted the d-shafts from both ends and drained the tranny. Also, the transfer case was dropped.
Picures::
Monday::
TJ and I unbolted the tranny and started pullin it.... I"m glad I'm puttin in an older tranny, none of that crappy electical connection crap!! and yes, that's all we got done monday, it was a PITA pullin the tranny without droppin down the exhaust.
I will be back out there on Thursday, so I will post updates by just editing this post.... Lemme know what you think so far.
==Ryan
Old Feb 2, 2005 | 03:38 PM
ChiefsFan's Avatar
ChiefsFan
Nice update Ryan but am I the only one that noticed the BIG DODGE banner on the wall!?!?!?!
Old Feb 2, 2005 | 05:18 PM
Lifted94XLT
Thanks Steve..... yeah, Slider's out in McClouth at my buddy's house, he's a BIG Dodge guy... heck, he's got a Ram on 38s.
--Ryan
Old Feb 2, 2005 | 08:04 PM
husker's Avatar
husker
Ryan good luck on the mods. You going to have it running by the 27th so you can try to break something at Tuttle?
Old Feb 3, 2005 | 12:37 AM
Lifted94XLT
haha, I should have it running by the 27th.... my goal is too have it running by the 6th, but you never know, I usually don't have very good luck with my mods goin the way I want them too. the biggest thing I'm worried about is the tranny, I rebuilt it myself, and it was my first rebuild.
--Ryan
Old Feb 3, 2005 | 07:42 PM
husker's Avatar
husker
You know the 2/3's rule. It will take twice as long as you planned on and cost three times as much!!!!
Old Feb 4, 2005 | 12:28 AM
Lifted94XLT
oh yeah, I def. know that.... but with all the connections I've got and the discount I get at work on parts, it will be a WAY CHEAP swap for what I'm doin....
UPDATE::
Just got back from being out there tonight.... I didn't get much done, b/c the torque converter probably won't be in until monday, so I'm just workin on the details now.... I removed the factory console brackets, and the rear seat A/C vents. I also replaced the carpet and the drivers seat so I could decide where I want the shifter.... this is a HARD decision.... b/c I don't have the tranny up yet, so I don't know where the twin sticks will be comin up at, and I don't know how high I want the shifter mounted...... oh yeah, I also removed all the wiring from my old stereo system.
--Ryan (sorry, no pics tonight)
Old Feb 11, 2005 | 12:17 AM
Lifted94XLT
UPDATE::
Tonight, I got what I thought was a lot done. I unbolted the A4LD flexplate and spacer off the rear of the engine, Cleaned up the space, then replaced it behind the new C5 Flexplate. I then finished installin the shift kit into the C4 valve body. It was when I was puttin the pan back on that I realized that the inlet where the pan goes into that pan at was serperate, meaning there's now a hole in the side of my pan, so I've gotta hunt down a "new" one now.
I also pulled the carpet back again to gain access (once again) to the hole in the floor for when the tranny gets bolted up, the twin sticks will have a place to stick through at. oh yea, I also made a REAL dumb move and knocked over a pan of old trann fluid.... yeah, like 6 quarts of fluid EVERYWHERE!!! That's all for tonight..... I have decided that I will just post all my pics once the swap is done.... and hae one big long post of just pictures from start to finish.
--Ryan
Old Feb 11, 2005 | 09:14 PM
husker's Avatar
husker
Keep at it Ryan and it'll get done. Sure makes one mad though when you run into those little road blocks on a project.
Del
Old Feb 13, 2005 | 12:26 PM
Lifted94XLT
yeah, and speakin of road blocks..... I had the tranny up behind the engine last night gettin ready to bolt it up, and I then realized that I need to BUY a new spacer for the c5 bellhousing. Grrrr!!! just prolonged the project another day or so. oh well...... (I'm tryin to git er dun by the 26th to go wheelin!)
Old Feb 13, 2005 | 11:11 PM
Lifted94XLT
Got the tranny bolted up tonight.
Now all that's left is:
Re-Install the Starter
Fab up a New Crossmember
Bolt up the T-Case
Install Cooling Lines
Modify and Install Driveshafts
Install Shifter
Old Feb 13, 2005 | 11:50 PM
97Centurion's Avatar
97Centurion
Rub my Belly
Sounds like you are getting there!
Old Feb 14, 2005 | 12:32 PM
Lifted94XLT
I'm gonna try and fab up a crossmember tonight, and then its all down hill from there.
Old Feb 14, 2005 | 12:46 PM
husker's Avatar
husker
Go Ryan!!! I'm home for lunch and thought I'd check in.
Old Feb 14, 2005 | 10:55 PM
Lifted94XLT
Pics:: http://www.cardomain.com/memberpage/420202/9
