trans problems
Old Feb 1, 2005 | 08:30 PM
jmp103182's Avatar
jmp103182
trans problems
ok my check engine light has been on for a long time but today i was messing around a little bit in 4 wheel drive came out of the woods went to back up and the trans was slipping bad would not back up get to house park it look in book go back out to mess with the truck and the check engine light is off stil wont back up very well slips bad but will move a little all forward gears are fine but when i let my foot off the gas it down shifts what does the manual lever shift postion sensor do by the way its a 96 f-150 with e4od never had trans problems before thanks josh
Old Feb 2, 2005 | 11:31 AM
Tailhunter18's Avatar
Tailhunter18
Have your codes check first..with the check engine light being on and all...First of all check the fluid level of the tranny as well as the condition of the fluid..sould be a deep red color..also check or change the filter...Lastly take er in and see what the pro's say.
Old Feb 2, 2005 | 11:48 AM
qman's Avatar
qman
Check that tranny fluid. You'll be able to tell if it's burnt by smelling it.
Bill97
Aug 15, 2013 09:35 AM
brandonn12375
Sep 19, 2010 07:11 PM
driver8k
Jan 29, 2010 03:56 AM
crew cheif
Apr 18, 2009 12:10 AM
wrmw
Sep 10, 2002 09:53 PM
