camera for horse trailer
Old Feb 1, 2005 | 07:37 PM
tazo's Avatar
tazo
do any of you wise souls know where to get a camera & monitor for my 05 f350 psd to monitor my horses inside the trailer and use as back up for behind trailer & truck
and be used as a dvd/tv? is it even possible?
thanks mike
Old Feb 2, 2005 | 06:16 PM
Cowboy Brett's Avatar
Cowboy Brett
I don't know of anything, but it is a swell idea.
Old Feb 2, 2005 | 06:33 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
I've seen motorhome's with a camera like you described used for backing up. So an RV supply might be a good place to start looking.
You could also check out a discount electronic's store. They sell inexpensive security camera kit's that contain several wireless camera's which would be perfect for your purpose. With 2 camera's you could alternate between horse's and backups. You would just have to make sure that the reciever could be made to run with a 12V system and then run the video out to a little dvd/monitor inside the cab.
Welcome to FTE and thanks for joining us in the Towing forum!
Old Feb 2, 2005 | 11:02 PM
tazo's Avatar
tazo
thanks horsepuller I will start at the local electronics store& rv site
Old Feb 3, 2005 | 12:06 AM
wmcutter's Avatar
wmcutter
Check out Costco if you have one close. They have several security camera set-ups for sale. One I saw has a split screen monitor and comes with two cameras. You could probably connect it to the truck 12V electrical system. That's out of my capabilities. Anyone have any advice, experience with this??
Old Feb 3, 2005 | 12:10 PM
Tuggingafiver's Avatar
Tuggingafiver
try this RV Frum site,,
http://www.rv.net/forum/index.cfm
go to the search site and check for rear cameras,, there are many towing 5th wheels that have installed rear monitors to see what is behind them,, should work well for the horses,,
Old Feb 4, 2005 | 05:02 PM
Ultraute's Avatar
Ultraute
See if you can find a portable DVD player (most all of these will run on 12 VDC), that has an aux video input. You could also use a laptop, as some have DVD players and aux video input. Just get a camera and plug it in.
There are also wireless "baby monitors" camera systems that run on batterys. B/W and no DVD. JM2C -Rob-
Old Feb 4, 2005 | 09:19 PM
tazo's Avatar
tazo
thanks for all the valuable info ! I can see I have choices and desisions to make------this is what makes FTE sooo great!
Old Feb 5, 2005 | 06:26 PM
Bordaine's Avatar
Bordaine
Use a rear camara system. Theres a company called Rostra make a camara system that replaces the rear view mirror with one with a moniter in it. The camaras can be mounted anywhere.
ProActive
All Things Towing
Jul 5, 2016 07:19 AM
psicorp
Mar 26, 2014 11:12 PM
roadkingfl
6.7L Power Stroke Diesel
Nov 30, 2010 09:45 PM
adbscu
Mar 25, 2009 02:31 AM
bkvanbek
13
Mar 28, 2008 12:57 AM
