Sponsored by: Auxito
Transfer case dry?
Old Feb 1, 2005 | 07:34 PM
Clint S's Avatar
Clint S
Trailering
Transfer case dry?
I have a 97 F`150 Automatic and noticed some leakage around the drive shaft seal on the transfer case. I noticed only because I heard some whining sounds coming from underneath, not good. My question is, is the transfer case fed from the tranny or does it have a separate fill plug and if so where is it? Also what does it take, Mercon or gear oil or??
I don't have a manual so am in the dark here
Thanks
Old Feb 1, 2005 | 08:14 PM
BSHORT's Avatar
BSHORT
Top Answer: 5
Seperate Fill And Drain. Use Mercon Atf.
Old Feb 1, 2005 | 10:10 PM
Clint S's Avatar
Clint S
Trailering
Thanks BSHORT
Old Feb 1, 2005 | 10:44 PM
Racerguy's Avatar
Racerguy
Hi Clint and welcome to the forum
The drain and fill plugs are on the back of the transfer case, somewhat hidden by the crossmember. You'll need a 6" or so 3/8 extension and a ratchet for the fill plug and just the ratchet for the drain.
acm05fsu
1997 - 2003 F150
19
May 1, 2010 09:56 PM
DBKER31
1997 - 2003 F150
Sep 3, 2009 10:51 AM
ol74hb
21
Jul 3, 2008 11:15 PM
steve604
Mar 10, 2008 06:16 PM
DarylZ
Sep 6, 2004 04:35 PM
