1978 - 1996 Big Bronco
Software to Edit the PCM
Old Jan 31, 2005 | 10:13 PM
pgrant1980's Avatar
pgrant1980
Question Software to Edit the PCM
Is there a cable to hook up to the odbII port and software i can load on a laptop as my father has a 96 Bronco EB with the 351 his is also the one that is made in CA as it does not have the air pump it is a 4x4 auto with the e4od transmission. if there is any thing out there that you guys know of i would be greatfull for the help. thanks in advance.
Old Feb 1, 2005 | 09:01 AM
WhëëlMå1's Avatar
WhëëlMå1
What exactly do you plan on uploading to the PCM? It sounds like you are asking for more trouble than you need. The easiest way to tweak the PCM is with an aftermarket chip. Yes, there probably are cables for connecting, but I wouldnt know where to find one.
Old Feb 1, 2005 | 08:40 PM
pgrant1980's Avatar
pgrant1980
well i had a 94 Camaro Z28 that there was a program called LT1 Edit that you could change everything from the injector pulse to the timing even tweek some of the sensor readings for like the o2 or iat sensor.
Old Feb 2, 2005 | 10:05 AM
adelyser's Avatar
adelyser
You cannot change anything in the PCM without actually disassembling it and removing the ROM chip. You're only option and because you have OBD-II, you can connect a laptop or palm device with a cable. This will allow you to monitor the sensors and log data, as well as reset trouble codes, but you still will not be able to change any fuel maps or timing maps. For performance tuning, you will need a chip from many of the companies out there. I would recommend one that you can program for your specific needs.
FYI, I use the ELM interface with my laptop from scantool[dot]net. It's cheap, and works great for monitoring sensors.
Aaron
Old Feb 2, 2005 | 08:13 PM
bossind's Avatar
bossind
Try tweecer.com they make a programer but you'll need to check to see if your computer is one that is supported, mine was.
Patina 69
20
Mar 5, 2011 07:25 PM
94 F-150 4X4
Oil & Lubrication
Mar 30, 2008 09:27 PM
Secret Agent 069
77
Mar 25, 2008 01:00 PM
voltson
Feb 23, 2008 10:16 AM
