Power Steering Conversion
Old Jan 31, 2005 | 11:33 AM
manlikesford's Avatar
manlikesford
I have a 1975 Ranger F100 4x4 with the ram assist power steering (if you want to call it that). I would like to convert over to the real power steering option and was wondering, does the donor truck need to be a f250 4x4 or F150 4x4 or will 2 wheel drive work? Also, is the 77-79 years the typical donor truck years to use? Also, can I use the tech article as my guide or is a conversion to 1/2 ton different than 3/4 ton? Thanks for any info given.
Old Jan 31, 2005 | 02:56 PM
73Custom's Avatar
73Custom
This tech article is all about swapping power steering onto a 67-79 F150 4x4. Did you look it over yet?
1/2 ton 4x4 power steering swap
Marty
Old Jan 31, 2005 | 03:31 PM
manlikesford
I fotgot about that article. I have since printed off. I have located a 1978 1/2 4x4 at the wrecking yard. They said they will give me all the items I need for $300. I think that is a pretty good price. Am I wrong? Also, on the tech article about the conversion on the F150, it mentions getting the steering boxed reworked for it to function correctly on the truck. It will turn left when you turn right. Why is that? Thanks for all the help.
Old Jul 21, 2005 | 11:20 PM
Cleetus's Avatar
Cleetus
manlikes ford,
I have the exact same dilemna - did you solve the problem ?
Thanks,
Cleetus
Old Jul 22, 2005 | 06:39 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Cleetus, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
rcmantooth
Feb 21, 2016 10:03 PM
1KILLERZ
General Diesel Discussion
Aug 7, 2014 08:12 AM
irondragon79
1966 - 1977 Early Broncos
Jul 25, 2014 10:55 PM
Harkijr
Jun 24, 2014 10:47 PM
OLD-F-250
May 2, 2004 12:57 PM
