67 F250 4X4 Power steering conversion
Here is the article from Glenn Davis. It worked great for me and was simple. Email me if you have and questions. I have a few pics also.
https://www.ford-trucks.com/articles/2003/23.php
Check out this gallery, https://www.ford-trucks.com/user_gal...90&albumid=8701
this is the kit found on Ebay installed on "76hiboy" ford F-250. I also have this kit on my truck also. I know the most important part is locating the gear box correctly. Maybe this will help. Good luck
Originally Posted by OLD-F-250
Thank you so much 4x4Subaru. This is exactly what I have been looking for. I have all the tools to do the job, just could not find the info to do it.
I'm also going to try and put the power brake setup on th 67 high boy.
I did the power brake thing also. That was even easier.
You have a very nice truck. Keep it stock if possible.
In my case, I did not want to spend the money in time to "create" a conversion. Plus I needed a steering shaft and pump which was supplied in the kit. When I added up the costs each way, I realized the kit would save me about $500 or more in saved time installing and sourcing parts. Not to mention it was all new stuff and had a warrantee which is what I wanted.
I do understand the $$ part. Just was trying to help as I am very happy with my kit. Take care, 460EFIhighboy
Mikes67F250
02-03-2015 06:36 AM
67M250Highboy
Arkansas Chapter
03-06-2012 06:09 PM
MADFord4X4
13
08-04-2010 01:24 AM
