Additional reverse lights
Old Jan 30, 2005 | 11:59 AM
DDD's Avatar
DDD
I have a 94 Flareside reg cab.I can not see out the rear sometimes at nite when launching the trailer. I was wondering has anyone added the fog lamp style back up lights ? J.C.Whitney sells the KC Hi Lites Kit fo 73.00! Due to my nite vision and Tinted windows I would like any Ideas or ijnput .They say (KC) it is a rather easy install... Any Idea comments or sugestions would be appreciated
Donavan
Old Jan 30, 2005 | 12:36 PM
Ultraute's Avatar
Ultraute
Why not try over watt (brighter) bulbs. Simple and cheep.
You can install any type of aux. lighting to the rear, but you should use use a relay, and wire large enough to cary the load. These can be controlled by the reversing switch, or by your switch.
Old Jan 30, 2005 | 01:17 PM
MemOrex's Avatar
MemOrex
lol, i thought of putting my old 55w fog lights as reverse lights on my 93. I currently have APC superwhite 3157 bulbs for reverse, but they look blue instead of superwhite....
They way to do it is with a Relay, like Ultraute said.
Old Jan 30, 2005 | 02:10 PM
Franklin2's Avatar
Franklin2
A relay will keep the original switch from being overloaded.
Old Jan 30, 2005 | 09:07 PM
mathelm's Avatar
mathelm
Unless you hook up a couple of 200w lights, over loading won't be a problem. I mounted 2 little requtangle ones on my roll bar right behind the off road lights. I don't know how I made it without them. I did mount a lighted switch on the dash so I could cut them off. So as not to blind anyone in a lighted parking lot.
Old Jan 30, 2005 | 09:48 PM
DDD's Avatar
DDD
Mathelm And 93Green
Thanks Guys! You all are great! I was thinking of the lights by KC hi lites only because JC Whitney said thay were easy and the price seems right .I am not too literate onelectrical but I can read,SonI do not think I will have a problem doing the Job
Old Jan 30, 2005 | 09:54 PM
DDD's Avatar
DDD
Mathelm ,
Do you have any pics of your handy work the switch and all
Old Jan 30, 2005 | 10:05 PM
MemOrex's Avatar
MemOrex
Hmmm...a switch sounds good....Maybe a quick flash for that guy behind you with his Brights on...lol.
I'll post my wiring and pics when i do mine. Gotta install my billet grill first .
mathelm's Avatar
mathelm
You mean you can't see them in that little pic next to my name?...... oh... wrong end......
Theres not much to see, which was the point. Small brite and low profile, same with the switch. But I can tell you, you really don't need the switch.
btw, the lights are wired to the backup lights and will only turn on when the switch is on and it is in reverse...
Old Jan 30, 2005 | 10:12 PM
MemOrex's Avatar
MemOrex
lol, mathelm, I bet that lights up the road.
Right now I have 2 55W Neon Coated lights on my grille (soon to come off as im putting a new grille in). I also have 2 55W Ion Gold lights under the bumper. Very bright!.
The bumper ones are powered through a relay. The relay is connected to my parking lights wire. That's the method I'll be using for the reverse lights, except the relay will be connected to the reverse light wire.
Old Jan 30, 2005 | 10:16 PM
mathelm's Avatar
mathelm
Sounds good. I'm a big fan of relays too. But with a 10ga wire running the backup lights you really don't need one.
Old Jan 30, 2005 | 10:32 PM
DDD's Avatar
DDD
Great Then That settles it=) I will get the set from JC Whitney and install them! It states that I do just that and it will not overload the system .It says just tap into the reverse lights and you should be ready to go!Like you said, Small brite and low profile!
Old Jan 30, 2005 | 11:33 PM
Franklin2's Avatar
Franklin2
I just went to JCWhitney and looked at the lights you are going to buy. It states in the kit that it comes with a relay. It has 2 55watt halogen lights. 55x2=110watts. 110 divided by 12 volts = 9.2 amps I would use the relay they give you to be safe.
Old Jan 30, 2005 | 11:54 PM
MemOrex's Avatar
MemOrex
9.2 amps + the Reverse lights + whatever else shares a more than likely 15Amp fuse. I would definetly use a relay.
Old Jan 31, 2005 | 10:45 AM
mathelm's Avatar
mathelm
I believe its on a 30amp fuse, even though a 15 would do. Plus I’ll bet that kit comes with a very thin 18-20 ga wire (knowing JCW). Now the most important part, Where should he draw power from? Maybe he should relocate the battery. I mean he may want to drive down the highway in reverse. So his choice is to connect directly to the backup light (6ft of wire) and if I’m wrong, blowing a fuse, or stringing 30ft of wire thru the frame and is a cheap relay away from having to ask someone if they have jumper cables. Look, a relay is just overkill for this application, I’ve been running mine for over 3 years now and this is not a vital system (ie Headlights ).
