Bronco II Ford Bronco II
Help!!!!
Old Jan 31, 2005 | 10:46 PM
DJ_FX's Avatar
DJ_FX
if you jump start it, DONT let it stall or shut it off. it wont restart.. you must run for awhile to charge, go for a little joyride, the higher the RPM, the better. when i bought mine, it had a dead battery and many other problems so it had 2 be boosted about 5times to get it home. (standard)
oh, a charger is a good thing to have around, watch for sales, i like the automatic but manual chargers are cheaper. mine is manual 6/12V, 2/6A. its from Canadian Tire, it dose a pretty good job, i think its worth about $30-40 CDN. you dont need anything fancy unless you have the extra money laying around and a hole in your pocket. but a nice feature to have is a setting for jump starting a vehicle, its like 50A setting i think. but ive never seen this feature in action so i dont know. a basic charger like i have is all you need.
Old Feb 1, 2005 | 01:56 AM
RomerB2's Avatar
RomerB2
There's still an underlying problem though isn't there?
Old Feb 1, 2005 | 03:45 AM
broncobilly86's Avatar
broncobilly86
Well I'd say he had the battery in there i guess new from the seller but it had not been fully charged so it drained and I think you have to get the charge up ...Make sure your belt is good to the alternator and stuff too. I have had a dead battery and gave her a real good run to get it charged up ..A little run dont always pull it off.
Old Feb 1, 2005 | 08:39 AM
stepman's Avatar
stepman
Originally Posted by Triphicus
Why do you think it isn't charging?
I say that because I know what people do to sell vehicles. The previous owner probably had a problem with it charging and to cover it up figured he'd just throw a new batt in there. That way it wouldn't be noticed that it wasn't charging. If you don't run the lights, a good batt will go about a week before it dies.If you have, or can borrow a volt meter, check the batt voltage after you start it up. A battery as weak as yours is now should show 13.5-14.0 volts @ about 1000 rpm's.
By the way...the battery on concrete thing is just a big myth.
One more tip is to remove and clean your battery connections. You can get a terminal cleaner for a couple buck at the parts store or Walmart.
Old Feb 1, 2005 | 07:17 PM
DJ_FX's Avatar
DJ_FX
Ive seen it happen. you can have it on concrete for a little while but it can drain the bettery then destroy it. (over a long period of time.. dosent happen overnight) but its still good practice not to put it on concrete.
Old Feb 1, 2005 | 08:30 PM
stepman's Avatar
stepman
It doesn't have anything to do with putting it on concrete. How can you drain an electrical current thru a plastic case into a rock? If you leave a battery sitting on the shelf long enough, it will "drain". Why can you set one on a metal shelf (conductor) and that's O.K.?
Old Feb 1, 2005 | 08:39 PM
DJ_FX's Avatar
DJ_FX
i didnt say it makes sense, or that i understand it. all i know is that it has happened... maybe its related to the fact the concrete is always cold. i dont know. and yes, metal is conductive, but if its on a concrete floor, what is it conducting to other then a big "rock"...
neither of us have scientific proof of anything. only thing is that it has happened where i work, the boss and his two sons leave their boat, snowmobile etc batteries there in the off season, everytime one ends up getting forgotten downstairs in the factory (on concrete floor) it is garbage when they go to charge it to take it back to their cottage. but when their upstairs like their supposed to be (carpet, dont know whats under it... office area) they charge up fine and are in same condition as when they were removed from the boat etc.
Old Feb 2, 2005 | 12:46 AM
Triphicus's Avatar
Triphicus
Thanks everyone for all of your help. Fortunately, this morning, as I was attempting to remove my battery to take it to the mechanics for him to charge it, I asked my neighbor for tools and he wound up looking it over and found that it was a faulty alternator. Thus, he offered to fix it for me if I bought the part!! Talk about a save of loads of money, haha. Anyway, I am glad to report that it is running great now and I look forward to finally driving it every day
Happy travels!
Sarah
Old Feb 2, 2005 | 08:17 AM
stepman's Avatar
stepman
Good to hear it.
Old Feb 2, 2005 | 12:33 PM
broncobilly86
Had a feeling it was the ALT ya got to have that baby working. Make sure the belt is on good with a good flex and your in action. As for the battery on concrete i have heard things like that but I think it happened to be just a few circumstances of bad batterys or batterys going bad ...not to sure ....It's like the old thing of got to cook the meat ya take out of the freezer or it'll go bad ...hehe. '''PUT''' it back in if ya aren't going to cook it ....lol all is good ya just loose a bit of juiceyness ....lol
Old Feb 2, 2005 | 03:16 PM
RomerB2's Avatar
RomerB2
If you put a battery on the gound, it will drain, although, you can put the battery on a piece of wood and then the concrete and it will be fine. I don't know why this happens but I know it does. Also if you do put batteries on the ground, they are more at risk to having leaks, and if the battery was on the ground, then when you put it in your vehicle, the cables will corrode faster. I don't have a scientific reasoning behind this, but I know it does happen. If you go into autozone or any place like that, you will also see that the batteries at the bottom, aren't on the floor, they're always on a shelf not touching the floor so they don't drain or leak.
Sarah Metcalf
Aug 9, 2014 11:02 AM
mcsc051511
New Member Introductions
Jan 14, 2014 11:02 PM
justruckin
1997 - 2003 F150
Dec 17, 2004 11:03 PM
sliknspeedy
Tennessee Chapter
Jul 20, 2003 12:34 AM
theologian
Tennessee Chapter
Mar 31, 2003 12:31 AM
