Sponsored by: Auxito
1998 F150 Overdrive Light Flashing
Old Dec 11, 2004 | 03:35 PM
justruckin's Avatar
justruckin
Unhappy 1998 F150 Overdrive Light Flashing
I crank the trunk, put it in reverse, and 30 - 45 secs after I start going forward the overdrive light starts flashing. It doesn't stop until I turn the truck off. I checked the transmission fluid and it's at the correct level. What could be causing this, and is it something I can fix?
Thx~ Brian & Sarah
Old Dec 16, 2004 | 07:50 AM
kylee's Avatar
kylee
the transmission shift solinolds are the problem need to have your dealer or transmission shop change one or both of them they are a common problem and are expencive
Old Dec 17, 2004 | 11:03 PM
dr jag's Avatar
dr jag
depending on the condition of the fluid, try a trans flush sometimes that brings things back to life, it's the cheapest place to start. if that does'nt work than get it properly diagged. depending on the condition of the trans. it may be the last death throws of the unit.
nice talkin to you
dr jag
