94 slow idle
Old Jan 29, 2005 | 08:29 PM
rbulla's Avatar
rbulla
94 slow idle
I have a 94 exlorer that is idling a little slow. It runs well, good milage, starts easily. I have 130K on it and have had very few problems. The manual says there is no adjustment. I'm I missing something, like a bad or dirty sensor or air valve, vaccume leak? It does idle smoothly, just slow.
Thanks in advance.
Old Jan 29, 2005 | 08:55 PM
jclj2003's Avatar
jclj2003
what is the rpms at on the guage
Old Jan 30, 2005 | 06:55 PM
rbulla's Avatar
rbulla
jclj2003,
Looking at the tach on the intrument pannel I would say close to 600 RPM. It's slow enough that the alternator drops out sitting at stop lights. I have the mannual transmission and made sure the clutch is not dragging.
Thanks
Old Jan 30, 2005 | 07:03 PM
jclj2003's Avatar
jclj2003
i dunno it sound like it is running a little low bc my truck runs at about 750 -800 rpm is it skiping or sputering. i would check the iac sensor to see if that could be the culprtit IAC = idle air controler it could be sticking causing it to run low
Old Jan 30, 2005 | 07:27 PM
rbulla's Avatar
rbulla
Thanks jclj2003,
I will remove the IAC this weekend and see if is leaking.
Old Jan 30, 2005 | 07:44 PM
jclj2003's Avatar
jclj2003
it wouldnot be leaking it would be sticking look at the top of the forum for info on the iac sticky
Daltongang
Nov 18, 2011 02:30 PM
T.McG
Dec 20, 2008 08:51 PM
1yamman350
1983 - 2012 Ranger & B-Series
13
Aug 8, 2003 01:55 PM
visegrip
Nov 13, 2002 07:41 PM
w4imm
Jun 10, 2001 03:17 PM
