94 ranger idle problems
Old Jul 27, 2003 | 08:01 PM
1yamman350's Avatar
1yamman350
my 94 2.3 5 sp 2wd is having problems idling. it starts easy and will idle good (maybe a warmup speed or something?) then it starts idling fast then slow and so on. i cleaned the mass airflow sensoron the airbox. any ideas could it be just because it has 387000 miles? know thats a lot but it runs like new with any throttle at all? thanks
Old Jul 27, 2003 | 08:25 PM
Ken00's Avatar
Ken00
Have you tried cleaning the IAC?
Old Jul 27, 2003 | 09:40 PM
nightme_02's Avatar
nightme_02
Mine did the same thing...check the Idle Air Control (IAC) and the Throttle Position Sensor (TPS), both located on the throttle body. Autozone will pull the codes for free if the Engine Light comes on...I think the TPS is about $12, and the IAC, there have been threads here saying there from $20-$65 depending on were you go...
If it's just idleing rough, good thing to start with is the IAC, If the RPM's are fluctuating while driving...TPS
Hope this helps!
Old Jul 28, 2003 | 05:23 AM
FyreLyter's Avatar
FyreLyter
Autozone doesn't check for free anymore...
At least in California
CA was going to fine each store 50,000 if they continued. they stopped about 8 months ago.
I guess in CA we will have to pay a full hours worth for 5 minutes of work. I think its time to invest in a code reader!!!
Old Jul 28, 2003 | 09:57 AM
1yamman350's Avatar
1yamman350
what do you mean by cleaning it? is their to metal things inside like the maf? my hanes manual says not to use solvent on the IAC solenoid? how should i clean it? do i need to disconnect it from the throttle body? also my relative has a 97 ranger 2wd 2.3. could i try thiers to see if mine is the problem or is it more complicated then that?
Old Jul 28, 2003 | 09:53 PM
nightme_02's Avatar
nightme_02
the IAC in my 94 2.3 is from a 94 F150 and I have never had any problems with it...I am not sure if the parts are differant..but they look exactly alike, and mount the same way...wouldn't hurt to try...as long as they are similar
Old Jul 28, 2003 | 10:20 PM
oduke's Avatar
oduke
Do not clean the IAC. Buy one and save the headache.
Old Jul 30, 2003 | 09:42 AM
FyreLyter's Avatar
FyreLyter
It's not a headache, since you have to take it off anyways to replace it, just clean it first. Cleaned mine and saved me 55 to 100 bucks.
Old Jul 30, 2003 | 12:27 PM
Ken00's Avatar
Ken00
Remove it and clean the passages with TB cleaner.
Old Jul 31, 2003 | 10:31 PM
oduke's Avatar
oduke
I stand corrected. I will clean the IAC this weekend and let you know what happens.
I hope the swap the EGR too.
Old Aug 8, 2003 | 09:43 AM
aberfoyle's Avatar
aberfoyle
I have a 94 2.3 5 sp 2wd as well, can someone confirm for me that the IAC on this vehicle is on the back of the throttle body near the firewall. If I remove it to clean it, can I re-use the gasket? Also, I was going to clean the MAF yesterday and discovered those nasty security star screws, where can I find screwdriver bits for them? Thanks much in advance.
Old Aug 8, 2003 | 11:09 AM
RangerRuss's Avatar
RangerRuss
Aberfoyle: The security star bits are available at many hardware and/or electronics stores. They are not expensive.
Clean your MAF with throttle-body cleaner not carburetor cleaner because of the coatings. As far as the IAC, also use the throttle body cleaner and clean the passageway inside the throttle body itself. Gasket can be reused if not damaged. Check for leaks around the gasket after reinstallation.
Good Luck
Russ
Old Aug 8, 2003 | 11:16 AM
gdoggy's Avatar
gdoggy
I ordered my security torx bit set from MCM Electronics for $6. Item number is 21-3241.
Here's a direct link:
http://mcm.newark.com/NewarkWebComme...jsp?id=21-3241
Old Aug 8, 2003 | 01:55 PM
1yamman350's Avatar
1yamman350
when i cleaned my maf i used pliers for those screws. they are not tight and if careful, u will not tear them up
Azfordracing
Mar 21, 2021 09:13 AM
gostephen
Jul 27, 2014 08:48 AM
rlwilson2
Jan 5, 2012 11:43 PM
Crazz
1978 - 1996 Big Bronco
Dec 4, 2004 09:15 PM
tatesomero
Apr 3, 2004 06:04 PM
