engine re-build
Old Jan 29, 2005 | 04:48 PM
jjenkins816's Avatar
jjenkins816
Question engine re-build
if i just replaced the cam shaft on my BB should i replace all the rollers, rods and rockers?
Old Jan 29, 2005 | 06:51 PM
stevef100s's Avatar
stevef100s
If it's a flat tappet cam, the lifters should be replaced. If it's a roller cam, the old lifters can be safely reused after careful inspection. The pushrods and rockers should be OK, but inspect them carefully also. Wouldn't it be a good time to install new pushrods and roller rockers? I would also install a new timing chain and gears.
