carburated 5.4
Old Jan 29, 2005 | 10:42 AM
Huntersbo's Avatar
Huntersbo
carburated 5.4
Has anyone ever built a 5.4 carburated?
Does anybody make the carburated intake for one of these?
I think that this engine is perfect for a light 4x4 with the long stroke and small displacement.
Old Jan 29, 2005 | 05:27 PM
2000BLK54's Avatar
2000BLK54
It's been done with a Kinsler IR setup. But talk about big $$$.
Old Jan 29, 2005 | 07:42 PM
superrangerman2002's Avatar
superrangerman2002
I guess I'd have to ask why one would even want to??
Old Jan 30, 2005 | 10:03 AM
LxMan1's Avatar
LxMan1
Less wiring mess in a transplant to an older vehicle. Ford has released 5.0 versions of the 4.6L that can be carbed now. I haven't seen anything on the 5.4L though.
Old Jan 30, 2005 | 11:44 AM
Huntersbo's Avatar
Huntersbo
the 5.4 has a 4" stroke and it is a small displacement, may be nice where a 400 is too much.
Old Feb 5, 2005 | 07:55 PM
towboat's Avatar
towboat
A carb on a modular engine...why? What about the ignition system, there is no provision for a distributor so you still have to have sensors and a computer to fire the coils.
Old Feb 5, 2005 | 08:48 PM
superrangerman2002
To me it would be easier just to transfer all of the essential electrics to the buggy, and clip the rest.
Old Feb 6, 2005 | 11:05 PM
LxMan1's Avatar
LxMan1
Edelbrock and MSD have a setup for the LS1 GM engine now that uses a stand alone ignition system and a carb. There is a lot less wiring involved and you wouldn't need the factory heavy wiring harness. They got over 500hp from a stock LS1 with the carb, intake, MSD set-up and a larger cam. Lots of power to be had. Plus you don't need the expensive high pressure, return style fuel system. A cheap electric pump and inline fuel filter in an older vehicle and you are good to go.
Old Feb 8, 2005 | 07:17 PM
towboat's Avatar
towboat
If I wanted a simple, inexpensive, carbureted V8 engine with plenty of power I would build a strong 351W and have my choice of any number of simple, inexpensive proven transmissions that would bolt directly to it. None of which would require a computer of any type. And there are a lot of intake manifolds to choose from for the 351 to match whatever RPM or torque curve you need.
If you want to spend a ton of money and get a headache trying to find specialized parts try to bolt a carburetor to an overcomplicated, overhead cam modular, and probably end up with less power than a well built 351W.
I don't see the point but good luck.
mightymoose95
1978 - 1996 Big Bronco
Sep 19, 2012 11:30 PM
frodfreak
Feb 1, 2011 11:14 PM
85300
18
Apr 14, 2010 02:26 PM
ClatonK
Alternative Fuels, Hybrids & Mileage
May 31, 2007 12:31 PM
