'88 F150 stranded
Old Jan 31, 2005 | 08:00 AM
MikeB 88's Avatar
MikeB 88
I had the same problem with my '88 several years ago. Driving home and it just quit running. Let it sit and it started right up. My problem wound up being the TFI module AND the computer decided to go belly up at the same time.
Old Jan 31, 2005 | 12:13 PM
Lumpy87's Avatar
Lumpy87
When the same thing happened to me (on a very busy road with almost no shoulder) the first thing I checked were the battery cables. It happened to be one of the tail wires from the ground had a splice come loose. I felt lucky to find it so quick.
Old Jan 31, 2005 | 01:21 PM
vohaul's Avatar
vohaul
my old ranger had theexact sameproblem...would drive fine..then just stalland not restart..wait anywhere from 15 min to 3 hours would start again......
i replaced the distributor nothing...
then replaced the tfi module...
worked fine ever since....
but man,wasit ever frustrating.......
cheers,
Paul
Old Jan 31, 2005 | 09:43 PM
clstrfbc's Avatar
clstrfbc
The TFI is about $50, so you'ld know if it was new. For the cost of the tow, you could just take it with you and put it in up there. If the mechanic puts it in he'll charge even if it doens't fix it.
Some auto stores can test the TFI, if it's dead they can tell you. If it's only mostly dead, they can't always tell.
Old Feb 1, 2005 | 09:57 AM
sumdumgai's Avatar
sumdumgai
The mechanic at the garage sent the TFI to the parts store. They said it appeared to be okay. I'm having it towed back to the garage. What's my position supposed to be with them? $250 later and still no fix. Thanks.
Old Feb 1, 2005 | 01:23 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
I wouldn't take it to the same place, they are just parts changers and not mechanics. Clean your battery terminals and check your grounds. Check your fuel pressure and check for codes. For $250 you could have bought all of the tools you need to work on this yourself.
'88 is an EFI, right?
Old Feb 1, 2005 | 07:35 PM
924x2150's Avatar
924x2150
Here's a tip..intermittant electronic problems can be simulated by heating and/or cooling suspected components. If you get your hands on the truck, try kiiling the engine at idle or induce a "no start" condition by carefully using a heat gun(not a blow torch) to warm individual parts up. If the engine is dead, you can cool parts using an aerosol cool-down spray which can be purchased at Radio Shack.
Your intermittant problem may also be related to loose or corroded electrical connectors, try going thru them one by one and cleaning them with electrical contact cleaner and an acid brush.
PS/ hasn't anyone pulled any diagnostic codes yet??
Old Feb 4, 2005 | 03:02 PM
sumdumgai's Avatar
sumdumgai
Smile It's the TFI, stupid!
Just got word from the garage that they believe they've fixed the truck. Replaced the TFI and it's been running well, and starting consistently, ever since. There went another $60 of beer and pizza money, but I hope the saga is over.
Old Feb 5, 2005 | 04:20 PM
clstrfbc's Avatar
clstrfbc
If it makes you feel any better, Probably 80% of shops would replace more than one part for this ignition system. 300$ is pretty good considering. It's pretty hard to find a shop that can fix an intermittant problem, unless you just loan them the truck for a couple weeks.
Jrod Webb
25
Oct 29, 2013 08:24 PM
rettus72
2004 - 2008 F150
Oct 15, 2012 05:54 PM
*2fords*
Dec 19, 2010 05:23 PM
JP66
17
Sep 1, 2010 09:48 PM
rsykes
1983 - 2012 Ranger & B-Series
Mar 1, 2005 01:47 PM
