68 Headlight problems
Old Jan 28, 2005 | 10:20 PM
PureRideJuno's Avatar
PureRideJuno
Unhappy 68 Headlight problems
I have a 1968 Ranger and both my headlights blink intermitently. They are on, then blink at the same time. They blink at around the same speed as the turn indicators. And i have checked all the ground and they are good. Any help would be nice.
Old Jan 28, 2005 | 10:54 PM
ACESN8S's Avatar
ACESN8S
If the grounds are good, then I would check the wiring at the headlight switch. See if any are loose.
Patrick
Old Jan 29, 2005 | 02:35 AM
Ford_Six's Avatar
Ford_Six
It sounds like something is grounding tripping the circuit breaker for the headlights. Check everywhere the wires have a hold down or pass through the firewall.
Old Jan 29, 2005 | 09:33 AM
flagator's Avatar
flagator
I don't know if it will help, but mine used to go from bright to dim with engine speed. I put a new Heavy Duty Battery ground cable (must be about 6 guage) with clear plastic insulation from Advance Auto. Cured the problem and also the problem with fuel guage and temp guage reading low.
Good luck.
Gator
