460 swap
Old Jan 29, 2005 | 11:05 PM
MacOffutt's Avatar
MacOffutt
I just happened to knowtice the previous post about a Crank Kit. What is that exactly, Sorry for *butting* in but Im just curious, cause I got a 360 that I want to make into a 390. Thanks
Old Jan 29, 2005 | 11:57 PM
Fomoko1's Avatar
Fomoko1
Butt in any time you need to as that is what this forum is all about! Crank kit is reground/remachined crank with the proper sized bearings supplied in a kit. So if you want to change up to the 390 then get the longer stroked 390 crank with the kit. A 360 engine had a 390 block with the shorter 352 engine( same block again) crank in it. Was not aware that the pistons were different as a 360 (1968) that I rebuilt years ago had 390 4 V stamped on it`s pistons. It is possible someone changed them but it didn`t appear that way at the time as it was not that old when I rebuilt it.
