winsor vs. Modified/High performance 4x4
Old Jan 28, 2005 | 08:12 PM
Huntersbo's Avatar
Huntersbo
351Windsor to the 351 modified:
which can make more torque?
I understand that the 351 M weighs 600 pounds and the 351 W weighsd 550 stock.
In a a light vechile like a scout 800 around 3400 lbs will it be toruqier with a 351M or a 351W ?
because I think weight hinders torque.
what differences do you notice when you drive the truck?
Old Jan 28, 2005 | 09:26 PM
Chris_ce's Avatar
Chris_ce
I think you may be better all around to use the windsor. If you go with the 351m why don't you just make it a 400. Now that motor has alot of torque.
Old Jan 28, 2005 | 11:48 PM
Huntersbo's Avatar
Huntersbo
thanks, I think that a 400 may be too much for a scout 800. A scout 800 is the size of a Bronco 2 and similar wieght.
Old Jan 29, 2005 | 12:31 AM
beeboy's Avatar
beeboy
400 is the same block as the M, just a differnt crank and pistons. Weighs the same, has more go.
Old Jan 29, 2005 | 11:11 AM
F150daniel's Avatar
F150daniel
351W 550lbs
351M/400 575lbs
300hp and 425ft-lbs is easy to get out of a 400.
Old Jan 29, 2005 | 11:33 AM
beeboy's Avatar
beeboy
keep in mind your tranny as they have different patterns.
The windsor has more aftermarket goodies available.
Old Jan 29, 2005 | 01:36 PM
The Shadow's Avatar
The Shadow
Thumbs up
BTW- Good luck with mounting that in a scout last time I looked International did'nt use motor mounts in the traditional sense. Two "mounts" at the bottom of the bellhousing and a plate at the front of the motor between radiator and front cover/timing shroud. If you decide to "rig it" definitely don't use the windsor. Timing covers are known for cracking in normal vehicles. Just my 2cents.
Old Jan 29, 2005 | 03:14 PM
monsterbaby's Avatar
monsterbaby
if you want to run a 335 series engine use the 351c same bore and stroke as the 351m or the W for that matter but uses the small block bellhousing, and the windsor motor mounts but I feel the heads (even the 2v heads) will outperform even most of the aftermarket windsor heads (barring all out race heads)
Old Jan 30, 2005 | 09:09 PM
Huntersbo's Avatar
Huntersbo
I will run a T-19 Granny, probably 31" tires with a 3.50 gears.
I might try to mount a Ford Engine mount in there.
I know that a bigger engine will use more gas, but will the miles per gallon be worst?
comparing the 351 M to the 400.
Old Jan 30, 2005 | 10:40 PM
good 'ol ford's Avatar
good 'ol ford
between the 351m and the 400 u wont see much difference if any under normall driving. the 400 has more touque so u dont have to be into it as much to get it going which makes up for the extra 49 inches
Old Jan 30, 2005 | 11:10 PM
Torque1st's Avatar
Torque1st
Posting Legend
They used to bolt Cleveland heads on the 351W and called it a Clevor. Intake parts are hard to find now tho.
Old Jan 30, 2005 | 11:20 PM
monsterbaby
hey Eric I think terry parker was making a funnel web for that conversion at one time, and may still be doing it, but I think he is the only one since B&A went out of business. although I heard someone else was supposed to be starting that back up.
Old Feb 1, 2005 | 06:24 PM
Huntersbo's Avatar
Huntersbo
HOw much should it cost me to build up a 400 or a 351M.
Old Feb 1, 2005 | 09:36 PM
Huntersbo's Avatar
Huntersbo
I do not think I want any more than a 351. This will be a daily driver and the 400 will make too much hp for a light scout, It has a 289 i it right now which fits in there perfect I think a 351 will be a tight fit. A scout weighs 2800 lbs stock I think that with 300 or more hP it will be like a dragster. I just want in the 200 hp range 200-250hp which I consider fast. HTe fastest thing I have ever driven is a '05 F-150 5.4L and I did not get to open it up, I liked how that thing really moved when I just touched the gas. I think when you have to floor it to make power you burn more gas then when it is fast at lower revs.
I would probably cam a 351 up to 4500 rpm max and run a 450 Holly and mabe headers.
Old Feb 2, 2005 | 07:02 AM
MitchPeters's Avatar
MitchPeters
Why not put a a good 302 in it? The weight would be less than the 351W and can be built to run well. Of course the 351W can be made to run well also. A mustang roller engine(cam) would be a nice block to stert with.
