First Things First
Old Jan 28, 2005 | 07:55 PM
sic inside's Avatar
sic inside
First Things First
i'm a new owner of a powerstoke diesel...i just bought a 01 F-250...i love the truck but don't know to much about diesel...i can't leave anything stock...my last to automobiles had alot of time and money put in them...i'm wondering about ideas for this diesel...if anyone has some ideas and some tips i'd love to hear 'em...thanx alot...~~BraD~~
Old Jan 28, 2005 | 08:03 PM
BigRed350's Avatar
BigRed350
You'll get plenty of ideas on this forum just about anywhere you look! Check out some of the older posts too. Welcome aboard!
Old Jan 28, 2005 | 09:15 PM
Pocket's Avatar
Pocket
I'll reply and maybe save you some time searching.
First upgrade should be gauges. Boost, pyro, and if you have an automatic, get a transmision temp gauge. With performance upgrades, you will need to monitor your turbo to keep it within safe boost levels (30 psi is probably max you want to ever go on a stock turbo). A pyrometer will help you watch your exhaust gas temps (EGT's), don't go over 1300 degrees for a long period of time or suffer eventual engine damage. With more power there is more stress on the transmission, so watch the temps there or you'll cook the fluid and dump a tranny.
Next, you need to build a foundation for more power. Intake will help your engine breath easier than it can with the stock airbox. A larger downpipe and exhaust will help on the other end to get rid of the exhaust faster and reduce backpressure. These upgrades alone won't give you much real power, but when you start adding other enhancers, the benefits go much much futher.
Now you can add a chip or programmer. Most chips are multi position and you can switch on the fly from one program to another. Many extreme programs are designed for race and not for everyday use. Keep it on a lower setting for normal daily driving, and switch to extreme for smoking up the neighborhood or showing off for friends. If you want a programmer instead of a chip, you get the benefit of a diagnostic code reader, but lose the ability to switch on the fly. Most programmers take a minute or more to switch modes, so see which one will work best for you.
Transmission upgrades would be a good investment if you have an automatic. Most chips and programmers will firm shifts "electronically", but the best way is to get a valve/spring kit. Most are easy to install, just a bit messy.
Those are the basics, after that the sky is the limit. Upgrading the turbo can include either a new turbine wheel (wicked wheel), or going with a high performance ball bearing turbo. Also new injectors can really wake your engine up. There are other mods that can be done such as CCV mod (crank case ventilation), 10K mod, EBPV delete, AIH delete, list goes on and on.
You can do a search for these if you have more questions. The only limit here is your pocketbook.
Old Jan 28, 2005 | 09:40 PM
FBINA109's Avatar
FBINA109
Fbina109
I went through what you are going through 3 years ago. I found this forum and consequently have relied on it for taking care of my rig. I started copying every idea that I saw (and seemed to be agreed upon by most members) and put them in a three ring binder. That way I do not have to search all through the forum for something I forgot. After a while you will get a feel for the people who really know what they are talking about and who gives the good advice. Like you have already received just above this post. Good Luck
1999.5 F250, 4X4, X-Cab, Long Box, Lariat, Auto. Banks Big-Head and exhaust, Banks Trans-Command, Gauges.
If you can read this thank a teacher. If you can read this in English thank a soldier. In memory of Spec. James Wolf 1982-2003 U.S. Army
Old Jan 28, 2005 | 10:15 PM
sic inside's Avatar
sic inside
thanx alot for all the help...all the stuff above will be of great use...it looks like i got alot of work ahead of me...and i can't wait...thanx again
