Ford F-100
Old Jan 27, 2005 | 06:15 PM
Todd40's Avatar
Todd40
Ford F-100
I recently acquired a 81 Ford F-100 custom 6-cylinder that wasn't started for about 3 years. I pulled the tank, drained the gas and installed a new fuel pump and filter. The truck starts, but idles rough and when I rapidly depress the gas pedal the engine tries to stall. When I gradually depress the gas pedal it revs up fine. Also, when I drive it it'll run a little rough and once in a while will stall like it's out of gas, but it'll start right back up.
I'm thinking that these problems are caused by one thing, but not sure what it is. Anybody have an idea or have you experienced this before? Or is there anything more I should do since the truck wasn't started for so long?
Thanks in advance
Old Jan 27, 2005 | 09:11 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Jan 27, 2005 | 11:05 PM
LxMan1's Avatar
LxMan1
If it sat that long, the carb needs to be rebuilt. It sounds like the carb has varnished fuel breaking loose and clogging ports in the carb. The bogging sounds like a gry rotted accelerator pump diaphram. I would change the fuel filter again too.
michea
Oct 9, 2012 11:04 AM
hunter1897
1978 - 1996 Big Bronco
Dec 9, 2007 10:25 PM
hebrew_hammer8
1983 - 2012 Ranger & B-Series
Nov 18, 2005 01:07 PM
cahilltlcpcc
Aug 24, 2004 01:30 PM
eric in tn
Sep 25, 2003 12:08 PM
