take off.....DIE!!!
Old Jan 27, 2005 | 01:46 AM
Fordbronco69's Avatar
Fordbronco69
Infidel
take off.....DIE!!!
My beast developed a new problem this morning....she started fine and got up to 160 F, put it in reverse and gave a little tap on the gas and it died. Started up again, put it in reverse and it died again. Started it up AGAIN and gave her HELLA gas and didnt die. It does it in Drive and reverse, im thinking it a carb problem. Stock 360 2bbl. Carb is a Reman.
Old Jan 27, 2005 | 01:59 AM
beeboy's Avatar
beeboy
check the accelerator pump..and for vacuum leaks.
Old Jan 27, 2005 | 07:34 PM
Fordbronco69
Infidel
pump is fine, checked it with a fuel pump tester, and no vacum leaks....i started to think it was timming but it only complicated the problem!
Old Jan 27, 2005 | 09:02 PM
beeboy's Avatar
beeboy
the accelerator pump is different than the fuel pump. It gives a shot of gas into the venturis when you give it gas, to prevent the carb from leaning out and sputtering/dying.
Old Jan 27, 2005 | 09:23 PM
Fordbronco69
Infidel
oh...you mean that little plunger thingy? thats been replaced with a new one about a month ago. Maybe i should take it back off and check it out?
I would say the problem only happends on 2-3 on the scale...
(No throttle "idle" 0) (full throttle 10)
0..1..2..3..4..5..7..8..9..10
Old Jan 27, 2005 | 10:29 PM
Fordbronco69
Infidel
I think i figured it out...my coil might be the problem. It gets plenty of gas...to much gas for the coil to burn off so ill try getting a new Coil go from there.
Old Jan 27, 2005 | 10:37 PM
MatthewC's Avatar
MatthewC
Or, your coil could be fine, and your running way too lean. Check your air/fuel mixture as well.
-Matt
Old Jan 27, 2005 | 10:44 PM
Fordbronco69
Infidel
ya...checked that, i tried tuning it to but it still sputtered when i gave just a tap on the gas.
Old Jan 27, 2005 | 11:01 PM
beeboy's Avatar
beeboy
you should be able to see the carb squirt gas from the accel pump if you look down in it while gassing it (with the engine off)
Old Jan 28, 2005 | 12:44 AM
Fordbronco69
Infidel
yes...i do see gas, its getting plenty of it. Ill see 2morrow if the new coil fixs the problem (crosses fingers)
Old Jan 28, 2005 | 12:37 PM
Fordbronco69
Infidel
man...im going to kill this thing! It wont spit n sputter when in park and N...only when theres a load on the engine like being in R or D! Maybe its the vacum advance on my distrib?
Old Jan 28, 2005 | 01:16 PM
beeboy's Avatar
beeboy
what's the vacuum adv hooked to on the carb?
Try putting your hand over the carb to block all the air going in and see if it dies.
Old Jan 28, 2005 | 01:26 PM
Fordbronco69
Infidel
theres a little nipple off the side of the carb that hookes up to a hose->vacum adv on distrib. ill try that hand thing....
Old Jan 28, 2005 | 02:15 PM
Fordbronco69
Infidel
BLAH!...its fixed now. Changed the timming and relocated the coil, the coil was arking onto the valve cover...how do i know this? Ask my finger...owey! Moved it away from the vavle cover and now it dosnt sputter! WOOOHOOO!!!
Old Jan 28, 2005 | 02:18 PM
beeboy's Avatar
beeboy
Great!! Poor finger! I wonder why the coil would arc though, was it at the wire, or off the coil itself? Something is bad there.
