1986 ranger 2.3L missing problems
Old Nov 7, 2005 | 12:51 AM
hebrew_hammer8's Avatar
hebrew_hammer8
hey, i have an 1986 raner with a 2.3L with 150k on it. when it just gets warmed up and is under load in 4th gear and the gas pedal is depressed enought to keep constant speed the engine starts to miss every 4 or 5 seconds causeing the vehicle to shudder. this happens for about 2 minutes then goes away. also if i give it gas past half throttle it won't miss. but if i let off it it'll start to miss and shudder. the whole ignition is new within 10k. what do you think it could be, i'm stumped
-zack
Old Nov 7, 2005 | 07:42 AM
tomw's Avatar
tomw
Possibly the EGR is being applied earlier than it is suppposed to be. It is held off until the engine is warm, and if applied too soon, can cause miss under load. Spark plug wires that are marginal, or large plug gap can cause the same thing. I know from experience.
Have you pulled the codes? Check there before spending any money chasing 'problems'.
tom
Old Nov 8, 2005 | 10:56 PM
hebrew_hammer8
that could possibly be it, the tube from the exhaust manifold is also broken too, could that be the reason for the egr being applied too soon?
Old Nov 17, 2005 | 11:20 PM
hebrew_hammer8
any help?
anyone have any other helpfull advise for my situation. its really annoying now driving around town half warmed up and it does this.
Old Nov 18, 2005 | 07:25 AM
tomw's Avatar
tomw
If you want more input on your problem, you will have to describe the symptoms a little more exactly. Misses are caused by several things: 1)bad mechanical components-valves,rings, etc 2) bad electrical (spark) or 3) bad fuel delivery - injectors or carb. Additionally, you can cause a 'trailer hitch' with a condition noticed under cruise, where marginal spark and minimum fuel mixture lean to a miss under load that comes and goes. If you add too much EGR (exhaust gas recirc) as noted, that can mimic the same symptoms as marginal plug wires. Did you check the gap on your plugs? Even if new, they are not guaranteed to be gapped properly from the factory.
Give us some more to work with, and you'll get deluged with 'information'.
tom
Old Nov 18, 2005 | 07:33 AM
Mauler's Avatar
Mauler
Do a compression test on the engine. I'm leaning to the bad valves or rings. My uncle's '86 with the 2.3 experienced the same issue. Two cylinders were had 0 compression.
RIP.
Old Nov 18, 2005 | 01:07 PM
JD717's Avatar
JD717
Well then, I'd say its time to do a rebuild of the motor.
Lucky
15
Jul 12, 2021 11:15 PM
56/78/92EFFIE
Nov 10, 2016 01:53 PM
TOM86
May 8, 2016 02:00 PM
NunchuckNorris
Sep 7, 2015 07:03 PM
