engine paint
Old Jan 27, 2005 | 03:35 PM
larry65's Avatar
larry65
engine paint
Hi. I was wondering if any of you have used Plati-kote engine paint and what were your results? I would hate to try it and it not last. TKS
Old Jan 28, 2005 | 06:28 AM
trike1946's Avatar
trike1946
Welcome to FTE. I never tried it. I use the stuff from Eastwood. I guess it would work. If you are planning on going in a show I would buy some good paint. Good luck with it.
Old Jan 28, 2005 | 12:03 PM
Greg 79 f150's Avatar
Greg 79 f150
My engine rebuilder used the Napa aerosol brand - color Ford 203 , on mine. It is still holding up , going on four years now. He chemical dipped the block to clean it in his machine shop. That is the key to any good quality paint staying on, cleaniness . Engines are really hard to get perfectly clean sitting in the truck, there will always be that little area that didnt get degreased well, and then the paint will start peeling at that point. Then once the bond is broken and the layer of paint lifts at the greasy spot, it just keeps peeling like a bad sunburn. jmo good luck
Old Jan 28, 2005 | 02:53 PM
larry65's Avatar
larry65
Ok Guys tks for the input.I did have the block and heads dipped so now they are pretty clean.I'm gonna try the plasti-kote engine primer and enamel so hopefully it will last.That is what my local Napa store sells here they say that they have sold it for years now and so far so good not any complaints.So here goes nothing!! TKS again.
Old Jan 30, 2005 | 02:54 PM
460f250's Avatar
460f250
I used it and it held up pretty well except in the really hot parts like on the heads near the exhaust and on the intake near the heads. Next time I paint I think I might use bar-b-que paint as a base and top coating with engine enamel.
abe
Feb 21, 2017 09:58 AM
abe
May 20, 2016 12:57 PM
Kadin Cook
Apr 21, 2016 10:44 PM
f2501967
Paint & Bodywork
Feb 22, 2008 04:29 PM
krehmkej
Feb 11, 2005 01:20 PM
