Sponsored by: Kumho
Shocks
Old Jan 27, 2005 | 02:03 PM
ssKable's Avatar
ssKable
Shocks
Ok, so I knew I needed some new shocks and was looking into getting some but was quoted more then I wanted to pay, however I recently had my trucks tires ballanced and rotated and they found the front driverside shock was snapped in half. Any suggestions on what type of shocks I should go with, I have a 99f150 4x4 supercab with a 5.4l v8, I do ocasionally go offroading but nothing serious, there are a lot of curvy roads out here. The cheapest I have found is at les schwab tires they quoted me about 240 for gabriel shocks they said they where the biefiest shocks they had, the other option was the mountaineer xlt or something like that, are these good shocks? anyone tried these before? any suggestions on other shocks? Thanks
Old Jan 28, 2005 | 02:19 AM
thesprocket26's Avatar
thesprocket26
I use ProComp es9000's on my off road truck. They handle well in the city and in the dirt. I got my set for like $130 from Summit.
Old Jan 28, 2005 | 02:07 PM
ssKable's Avatar
ssKable
How hard would it be to install them yourself? is there any tech articles online that anyone could direct me too or any books I could buy with instructions, I've seen it done before on tv it doesn't look too hard as long as you have a lift and the right tools. I might be able to get access to a shop that has a lift. It would be much cheaper to do it myself, I was thinking of getting the moroe reflexes or the rancho rs5000's.
Old Jan 28, 2005 | 03:08 PM
jtmerritt's Avatar
jtmerritt
Installing shocks is not difficult and with your truck being a 4X4 you wouldn't have to put it up on a lift but if you can that would just make it easier. If you have the tools the install is really pretty easy. If each shock comes with a plastic or nylon retainer to keep the shock from extending, don't cut that off until you have mounted the shock or at least one end of it. Once you cut the retainer, the shock will extend and you will have to compress it to get the other end connected. If you are lucky you can guide the shock into position as it extends and not have to do any compressing of the shock.
John
Old Jan 28, 2005 | 03:17 PM
ssKable's Avatar
ssKable
I have my torsion bars adjusted so that I can clear my 285/75/16 bfg all terrain tires, would I need to order a shock that is a little longer? also would the shocks come with instructions like for the compressing? how do you do that?
Old Jan 28, 2005 | 07:02 PM
mino54's Avatar
mino54
buy BILSTEINS shocks, they are the best and life time warranty ($ 75.00 ea.+-)
Old Jan 28, 2005 | 08:23 PM
wickymustang's Avatar
wickymustang
Lifetime warranty agaisnt what? So if I put them on my truck and the salt kills them in 10 years do I get new ones free? In terms of softness where do they land compared to like the rs5000's?
Old Jan 29, 2005 | 02:07 PM
ssKable's Avatar
ssKable
I'm not lookin to spend a lot of money, not more then like 35 per shock at the most.
Old Jan 29, 2005 | 05:31 PM
thesprocket26
ProComps are about 34 bucks. You can compress the shocks with your arms and hands. You got to use some strength.
Old Jan 30, 2005 | 02:24 PM
ssKable's Avatar
ssKable
question about rancho shocks if anyone knows, according to rancho the part number rs5233 is for the front shocks and rs5234 is for the rear, part number rs5246 is the rear for an expedition, on ebay I found a set of all 4 shocks that claim they work on f150 and expedition but the part numbers they list are rs5233 and rs5246. Does anyone know if the part rs5246 for the rear shocks on an expedition will work on my f150?
Old Feb 7, 2005 | 06:44 PM
mino54's Avatar
mino54
Smile
yes; they will replace them for free
the life time warranty is against anything that goes wrong with any or all of them.
kyb's and monroes have the same warranty == life time==
i like billsteins because they are the BEST for shocks under % 100 ea.
they are what the upper end sport cars come with from factory.
you get WHAT YOU PAY FOR..
I LIKE (DEMAND) A SHOCK THAT IS GOING TO KEEP MY TIRES ON THE PAVEMENT. ...so much better ride with confidence.
RAIN OR SNOW
regards.
Old Feb 7, 2005 | 08:08 PM
Buzzman222's Avatar
Buzzman222
Im VERY happy with my Edelbrock shocks. Almost went with some Billsteins but i chose Edelbrock over them. Might wanna check edelbrock out.
Old Feb 8, 2005 | 02:21 AM
ssKable's Avatar
ssKable
Thanks for all the info, I ordered 2 rancho rs5000's for my truck and they are awsome I love them the ride is SO much smoother and handling is much better and I only replaced the front two, If I had the money I would get a set for the rear but I need my brakes replaced next, aahhh the joys of owning a vehicle
ZackYoung
Apr 10, 2017 08:12 PM
Whitetail2017
Mar 12, 2017 03:27 PM
highway90
Jan 23, 2017 05:16 PM
ahiaring
Jul 14, 2016 10:10 PM
b2trausch
Oct 23, 2007 08:36 AM
