exhaust ?
Old Jan 27, 2005 | 01:00 PM
864x4stepside's Avatar
864x4stepside
Question exhaust ?
Need new pipes on my 86 4x4 stepside, want to run them both out in front of the rear passenger tire, just under the step. Has anybody done this with dual exhausts? Another concern is will the exhaust fumes be sucked into the cab thorugh the rear sliding window while driving? Thanks in advance.
Old Jan 27, 2005 | 09:29 PM
Sycostang67's Avatar
Sycostang67
I did that with my 79 stepside, headers and straight pipes, exit under the passenger step. If you have women in your truck, you may want to put mufflers on, because thats all my wife complains about in that truck. She can't roll the window down because it's too loud. Some times when idling, if the wind is just right you will get some exhaust fumes through the passenger window, but nothing that will send you to the hospital......... unless you burn tons of oil. I don't think you need to worry about fumes while you are driving coming in through the back. I think the turbulence around the bed will blow it away. Only vehicle I had that problem with was a bronco, had no rear window, the flat back causes the air to rush up from under the truck and into the back window. The lack of a tailpipe didn't help the situation either. That cost me a $1200 visit to the hospital.
Old Jan 28, 2005 | 03:55 AM
Towmanjbo's Avatar
Towmanjbo
Before you do this check with the emmission laws in your area. I wanted to put side pipes on an old truck of mine and was told by the muffler place that they couldn't do that in CT on that truck. The law here is it must come out where the factory put it, before or after the rear axle that is.
Old Jan 28, 2005 | 10:17 PM
MontanaFord's Avatar
MontanaFord
Glad I live in Montana. No emissions, and you can run just about whatever exhaust however you want, whenever you want. YEEHAWW!!!
MontanaFord
Old Sep 20, 2005 | 07:47 PM
nickmobile67's Avatar
nickmobile67
I wanted to do that with my flareside, but with keeping the cats for emissions/inspection I've picked up a flowmaster dual setup that comes out like that off of one muffler, but exits behind the rear tires. Havn't put it on yet though. I think it's for 87 up, but it looks like it will clear everything ok, may be a little tight around the spare tire though. Anyone try this setup before???
Old Sep 20, 2005 | 10:12 PM
mustange70's Avatar
mustange70
If it will fit the older trucks it should fit the older trucks, as everything underneath was practly the same.
As far as running the exhaust in front of the p-side tire you must be aware that the exhaust will stain the p-side back tire over time (just look at diseals and all the crap the exhaust leaves on the paint), but if you take car of it it won't matter much.
I myself went with a single 3" exhaust with an exhaust cutout, dynomax super turbo and it sdumps behind the p-side tire through a 4" tip, looks awesomes and sounds great .
Old Sep 20, 2005 | 11:24 PM
Towmanjbo's Avatar
Towmanjbo
OK,uh... Yea
Old Sep 21, 2005 | 12:04 AM
85F_150driver's Avatar
85F_150driver
As long as the gas tank is in the rear and not on the drivers side then you can run them where ever you want pending emissions laws. The common problem on most duals setups is the gas tank on the drivers side inside the frame rail. With the tank on the drivers side you would have to run both pipes over the rear axle and then in what ever direction you want.
Old Sep 21, 2005 | 06:42 AM
nickmobile67
That's the way this flowmaster setup is, it dosn't go over to the other side until after the axle, so it's close to my tire carrier. My gas tank is almost in the middle of the truck, it would work better for me if it spit before the axle.
I knew the frame is probably almost identical in 87 as it is to my 86. I really don't want it to block my spare though.
Old Sep 21, 2005 | 06:05 PM
mustange70's Avatar
mustange70
OK,uh... Yea
lol, well you know what i mean . Yeah if its fits the newer trucks it'l' fit the older trucks .
Aremee
Mar 30, 2016 06:58 AM
ola1234
Mar 11, 2015 02:46 PM
78_f800crewcab4x4
Jan 4, 2015 11:07 PM
gtrosema
Vehicles for Sale
Oct 8, 2014 03:25 PM
mustang81
May 30, 2014 08:31 AM
