00 explorer cold over heat
Old Jan 26, 2005 | 06:19 PM
reddude's Avatar
reddude
2000 explorer momentarly over heats on a cold start just before the thermostat opens, the gage pegs,the check gage light on, the hoses are cool to the touch then warm with a slight bubbling of coolant,the coolant originaly tested to 10 below with amb temp of -2 deg
a new sending unit was installed,the thermostat was changed twice, coolant flushed, filled and checked ,the heater valve was also checked
a "block check" was performed and no combustion byproducts in the coolant,water pump removed and inspected seems ok, no external leaks,no coolant in oil
this occures after sitting outside on cold nights
any suggestions, could this be trapped air, a head gasket on it's way out or a cracked head?
has anyone else experienced one like this?
Old Jan 26, 2005 | 07:25 PM
Steina's Avatar
Steina
CO River Rat
Red -
What does the new coolant test at? A 50/50 mix should protect better than -10, and wind thru the radiator can drop the temp even lower.
Was the water pump matched against a new one when it was removed? Vane erosion isn't always apparent if you don't match it against a new pump, and might "seem OK".
Steve
Old Jan 26, 2005 | 08:15 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
50/50 should be about -25. does this do this just when it is really cold. 10 deg or colder. or higher than this. If it was when really cold then the antifreeze might be getting toward a solid (slushy) form and is not flowing, thus the overheat. open the hood just before starting and open the cap or look in the overflow to see what the antifreeze looks like (liquid or slushy). If it is even a little slushy add antifreeze or change it.
Old Jan 26, 2005 | 08:20 PM
CTford's Avatar
CTford
Well, the bright side is that you should be getting PLENTY of heat from the HVAC system in the cabin!
Old Jan 27, 2005 | 08:32 AM
reddude's Avatar
reddude
coolant is at 50/50 mix and was replaced with the thermostat
no slush visable
Old Jan 27, 2005 | 10:09 AM
bigredtruckmi
Veteran: Navy
sounds like a coolant flow problem. good luck
Old Dec 8, 2005 | 02:47 PM
benratt's Avatar
benratt
5th Gear
What did you figure out the problem was? I friend of mine's Mountaineer is doing the exact same thing and we can't figure it out. Thanks ,Ben
westkane
Nov 10, 2012 09:08 PM
38Chevy454
Modular V8 (4.6L, 5.4L)
Jan 18, 2011 11:08 AM
jstone400m
Jun 24, 2007 10:47 PM
qkos
Apr 6, 2005 09:20 AM
1explorer
Jan 27, 2003 04:54 PM
