Sponsored by: Innova
need opinions...please
Old Jan 26, 2005 | 02:01 PM
jrip16's Avatar
jrip16
I have a 2004 F-150 Screw and I have just replaced the factory unit with an Alpine CDA-9830 and I put Pold db 570's in the front doors and Alpine SPS-570A in the rear doors. (I also have an i-pod unit attached to new head unit) I want to make the sound a little more balanced by adding a sub. It does not have to rattle all the windows but I want it to compliment the existing sound. I also want to make sure that it is not visible, as in putting it under the driver side rear seat. Now here is the kicker, I would like to spend less than $200, actually I was thinking more about $150 and i am doing my own install. This may not be realistic but that is where I am at on this right now. Thanks for any input.
Old Jan 27, 2005 | 10:29 AM
rangerxlt02's Avatar
rangerxlt02
It's going to need to be a small enclosure. I know that Q-Logic makes a custom fit enclosure for under the driver side rear seat, and it only has an internal volume of .65 cubic feet.
With that limitation in mind, you can make your own enclosure that should have about the same amount of cubic volume space. Then you can go with a sub like one of the following:
Polk Audio db104 10" 4-ohm component subwoofer
Alpine SWE-1041 10" Component Subwoofer
Rockford Fosgate P110S4 Punch Stage 1 10" 4-ohm component subwoofer
The 3 subs above will run with a .65 enclosure, and are all less than 100 bucks. You will need to make the enclosure yourself, otherwise you'll go over your budget you've set.
Later
Old Jan 27, 2005 | 11:48 AM
jrip16's Avatar
jrip16
thanks for the input on that...someone else mentioned Kenwood wOOx or a powered sub that Infinity makes. Do you know much about them?
mtnbird
Jan 6, 2014 02:00 PM
tkean11
Jul 10, 2004 12:57 AM
SeannyBoy84
Mar 2, 2004 03:05 PM
