Sponsored by: Real Truck
ZF6 oil
Old Sep 30, 2015 | 11:17 AM
artieb's Avatar
artieb
ZF6 oil
Hi, I have a 01 Superduty with a ZF6, 268,000 miles. I am using regular ole ATF. I want to change the oil soon, and would like know what has been working in there?
I have a grinding when I try to downshift into 1st, or whatever you want to call, the normal take off gear ( not the granny gear opposite of reverse/granny gate ).
I have used Pennzoil synchromesh, in other applications that has worked well, in backlash, not preload transmissions, like the ZF6.
Any ideas? Thanks, Artie
Old Sep 30, 2015 | 11:45 AM
KellyfromVA's Avatar
KellyfromVA
At the risk of starting another oil debate; I changed mine to Redline Synthetic ATF. It may be my imagination, but it seemed to shift smoother and I eliminated the rollover (klack klack) when you push in the clutch after being under load: Red Line Synthetic Oil - Automatic Transmission Fluids - D4 ATF
Old Sep 30, 2015 | 06:45 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I use Amsoil full synthetic ATF, but do have gear roll over when towing heavy at various times. Although, since I bought the truck a year and a half ago and changed the fluid twice, the gear roll over is not as bad as it used to be.
flipklos
Aug 26, 2011 06:52 PM
lazyscholar
Oct 18, 2008 07:09 PM
884x4broncoII
15
Mar 9, 2008 12:55 PM
93Mule
1978 - 1996 Big Bronco
Apr 13, 2007 03:19 PM
Miller
Dec 30, 2006 06:23 AM
