Replacing Dash Lights
Old Jan 26, 2005 | 07:14 AM
n2umr's Avatar
n2umr
I need to replace a dash light behind the fan speed control **** and I don't know how to remove the dash properly. Is there a trick to it like removing the radio first? I don't want to break my dash replacing the light bulb.
Mark
Old Jan 26, 2005 | 09:07 AM
dakota_viking's Avatar
dakota_viking
Mark,
You should be able to gently pull the trim around the heat controls/radio as it is attached to the dash with clips. The radio doesn't need to be removed. Once the trim is removed, you should see the screws holding the heat controls in place.
Good luck and take your time,
Tim
Old Jan 26, 2005 | 09:38 AM
MOOK929RR's Avatar
MOOK929RR
not a bad idea to grab a Haynes manual for like $15, it shows how to take it all apart, step by step, with pictures.
lindazman
Dec 7, 2015 06:35 PM
66shadow
May 11, 2013 11:57 AM
nothercrash
Nov 27, 2012 09:38 PM
Downriver Thunder
Apr 10, 2009 10:39 AM
80s Trucker
Mar 8, 2006 10:49 AM
