I need to replace a dash light behind the fan speed control **** and I don't know how to remove the dash properly. Is there a trick to it like removing the radio first? I don't want to break my dash replacing the light bulb.
You should be able to gently pull the trim around the heat controls/radio as it is attached to the dash with clips. The radio doesn't need to be removed. Once the trim is removed, you should see the screws holding the heat controls in place.
