1978 - 1996 Big Bronco
Need Heat
Old Jan 25, 2005 | 08:53 PM
capitol's Avatar
capitol
Need Heat
had thermostat replaced, refilled antifreeze, got all air out, no heat. All shops say nothings wrong. Its 20 degrees outside. It appears that no fluid runs through core.just dont understand?
Old Jan 25, 2005 | 08:56 PM
JBronco's Avatar
JBronco
Sounds like your heater control valve is stuck in the closed position. Sometimes they break inside and you can still move the cable, but it's not turning the valve inside the hose.
OR - you have blockage in the heater hose(s) or in the heater core itself.
Old Jan 25, 2005 | 08:59 PM
Trublufords's Avatar
Trublufords
Year????????
tjc transport
Feb 12, 2010 03:36 PM
miner999r
Feb 14, 2009 11:07 PM
kyfireopal
1997 - 2003 F150
Dec 8, 2006 07:56 AM
cobraguy
Dec 30, 2001 12:59 AM
