This year my heater isn't heating like it was before. The heat isn't as hot, plus when I"m driving, it will be heating and then all of a sudden go to blowing cold air. Then the heat will come back on a few minutes later. I know it's a 97 with 172000 miles on it, but what would be making it do this? ANy ideas? Thanks.
If its on turns you mostly notice the change, or stops, you probably have a broken blend door. New plenum, full dash pull. Otherwise your blend door controller is "wandering" but that would be pretty rare. Of course with 172000 miles anything is possible.
